A/C Condensor drain - where is it?
Old Mar 6, 2000 | 06:13 PM
frank_1's Avatar
frank_1
I/ve got a 2000 ranger with a 4Cyl engine. My a/c is putting out a terrible smell, which is generally a sign of a clogged drain. My problem is that I can't seem to find the drain to check it. I have no water dripping at all when the a/c is on, so I think I'm probably on the right trail, but I have looked everywhere and can't find the drain tube. Anyone have any help?
Thanks
Old Mar 8, 2000 | 06:16 PM
Mark P
Guest
Posts: n/a
the condensor is ahead of the radiator, and the evaporator is in/under the dash board. Not sure were the drain is on your trucks evaporator but they usually come out in the passenger side wheel well.
Old Aug 11, 2000 | 10:05 AM
ke6bnl's Avatar
ke6bnl
Yep the evap is the cooling source, and in most vehicles I have seen the drain is a rubber tube that extends out of the fire wall I just Took and air hose and a 1/4 in copper tube and blew it into the cab and the water started to flow. good luck ke6bnl
Old Aug 11, 2000 | 09:44 PM
nitro94's Avatar
nitro94
In most cases if you will find where the a/c hoses go thru the firewall the drain will be right below that point. If the evaporator is in a housing in the engine bay the drain is a cut out in the bottom of the case.
Old Aug 14, 2000 | 06:30 AM
TallPaul's Avatar
TallPaul
