more gas milage
Old Jul 15, 2008 | 10:26 AM
96_fordF150's Avatar
96_fordF150
Smile more gas milage
well i gutted out my cat the other day and disconnected the o2 sensor after the cat on my 96 f150 302....i was roughly getting 10 mpg...150 to 160 on a tank of gas...this is with 6 inch lift and 35in tires on stock gearing...now after gutting my cat and disconnecting my sensor im getting about 12.5-13.5 mpg....just thought this was something worth posting
Old Jul 15, 2008 | 12:56 PM
Conanski's Avatar
Conanski
The sensor after the cat is only for monitoring the cats efficiency and has no affect on the engine operation. Hollowing out the cats gave you your milage improvement(just goes to show how restrictive they are), and stepping up to at least 4.10 gears would net you another couple milage points.. assuming the motor is in good operating condition and not throwing codes.
Old Jul 15, 2008 | 02:36 PM
skaterbro's Avatar
skaterbro
Or you could spend a little money and buy a hi-flow 3way cat, and NOT be a gross polluter.
