Modular V10 (6.8l)
Lp Gas
Old Jul 14, 2008 | 09:48 PM
fgvanwhy's Avatar
fgvanwhy
Lp Gas
Hi Guys
I haven't been on in a while. I have a question to run by you. Has anyone tried or thought about tring to convert there V10 to run on Propane? I was looking into it for my Dually. I would like any feed back. My truck works fine now but I am looking to the future and the price of gas. The price of LP is about .50 cheaper than gas.
Thanks Frank
Old Jul 15, 2008 | 01:15 AM
mikehm's Avatar
mikehm
LP Gas
Frank, I dont think you would save any money, LP Gas may be cheaper, but you wont get as good a mileage with it as you do with regular gas.
LPG doesnt have as much energy in it as gasoline, so you wont get as much power or as good a mileage.
And to convert from MPFi to LPG and install a DOT approved LPG tank would be a nightmare. And I'm not sure about the engine control computer. Plus it would be vary costly, and you have to stop to get LP Gas every 150 miles or so. None of this 400 mi per tank like with gasoline.
I dont think you would be vary happy with it.
Mike.
Old Jul 15, 2008 | 05:51 AM
projectSHO89's Avatar
projectSHO89
Propane has 74% of the energy content of gasoline. You'll have to do some calculation to see if it's worth it.
Steve
Old Jul 15, 2008 | 07:03 AM
marcussen's Avatar
marcussen
I have seen some V-10 for sale with Compressed Natural Gas (CNG) but a conversion cost $10000 + so even though CNG is about $.93 here, it is hard to justify. Plus it's hard to find a place to fill it up. But a home filling station for about $4000 will let you fill it up at home. CNG has a higher energy content than gasoline so your MPG would not change.
Old Jul 15, 2008 | 07:22 AM
projectSHO89
CNG has only about 1/4 to 1/3 the energy content of gasoline per gallon. It does not have more energy content.
Citation: http://www.eere.energy.gov/afdc/pdfs/afv_info.pdf
Steve
Old Jul 15, 2008 | 02:18 PM
dkf's Avatar
dkf
FWIW I buy about 500lbs of LP every winter and it goes up every winter. Paid $60 for 100lbs last winter and I can only imagine what it will be this winter.
Old Jul 15, 2008 | 05:06 PM
Heavy_Metal's Avatar
Heavy_Metal
It would be nice as a bi-fuel setup but not for $10k.
Old Jul 15, 2008 | 06:11 PM
rustyfuryiii's Avatar
rustyfuryiii
Some of the trucks used to pull heavy aircraft around the terminals at a few airports use V10s powered by LPG.
On Monday a large, new, yellow, Blue Bird, school bus passed me with placards on it saying "Powered by clean LPG". Thirsty guy that I was, I pulled along side her and held a canteen to the exhaust pipe. mmmmm that slaked my thirst!
On the flip side I just paid $774 for around 265 gallons of LPG.
Google V10 and LPG you may find what yer looking for.
Enjoy,
RustyFuryIII
Old Jul 18, 2008 | 09:59 AM
fgvanwhy's Avatar
fgvanwhy
Thanks guys, I was just kicking around an idea. At that price to convert I will stay with what I have. I don't use my truck evertday so I can go a long way for $10,000. I like the power it has now so if you lose power with lp gas it don't make sence to change. Have a nice day
Old Jul 18, 2008 | 12:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
My 2001 service manual shows dual-fuel setups for the V10 - it was apparently available with either propane/gasoline or CNG/gasoline as an option.
You MIGHT check out if there's any out there in the junkyards across the nation and use the parts - it would involve a LOT of work.
Old Jul 18, 2008 | 01:48 PM
dkf's Avatar
dkf
Or find a V10 in an industrial generator application running nat gas or lp and do the ole switcharoo.
Old Jul 18, 2008 | 01:53 PM
krewat's Avatar
krewat
But would something like that be driveable with a go-pedal?
Acceleration (enriched), coast, etc...
Hmm...
Old Jul 18, 2008 | 01:55 PM
krewat's Avatar
krewat
Like this one?
YouTube - QuietRun Ford Powered 110 kW Generator
Old Jul 18, 2008 | 01:56 PM
krewat's Avatar
krewat
Ooohhh.... Ahhhh....
Ford QUIETRUN 110 kW Propane/Natural Gas Generator - eBay (item 330253690787 end time Jul-24-08 04:56:26 PDT)
Old Jul 18, 2008 | 03:18 PM
dkf's Avatar
dkf
Hmm...
Thats a good question and I honestly don't know. It seems like the generator is made to run a certain rpm and done. After looking at your links, it says the generator operates at 1800rpm, which seems very low to me. Wonder if the manifold and fuel system could be carried over to an over the road V10.
