Modular V10 (6.8l)
which gears
Old Jul 14, 2008 | 08:54 PM
rich250's Avatar
rich250
which gears
got an appointment for next mon. to have my gears changed out,I originally was going to go with 4:56's but after some talk with the guy at the axle and driveshaft shop he thinks I should go with 4:30's,my tires are 265/75/16 and staying that size,now if I was to go with the 4:56 gears and it would be to much gear then I would consider slightly larger tires.the reasoning for the gear swap is I pull an 8000lb or so camper and I want more pull for hills,so which gear do you guys think I should go with.
Old Jul 15, 2008 | 03:09 PM
spinella's Avatar
spinella
how much towing vs. everyday driving do you do?
Old Jul 15, 2008 | 05:01 PM
Heavy_Metal's Avatar
Heavy_Metal
If you're staying with the stock tires, 4.30's are perfect.
Old Jul 15, 2008 | 07:49 PM
rich250's Avatar
rich250
my truck only tows I drive an escort everday
Old Jul 15, 2008 | 08:05 PM
spinella's Avatar
spinella
i agree with heavy metal i have your same set up except f350 with 35" tires my travel trailer is about 8500lbs. and i have no problems.i do hills maybe once or twice a year.(long island is pretty much flat.)4:30's will be great for the inclines.
Old Jul 15, 2008 | 10:40 PM
newfordrichy's Avatar
newfordrichy
Smile
2006 F250SD, extra cab, 4.10 diff and I pull a 30-foot 5th wheel with a combined weight of 16,000 pounds. I can climb most grades at 50 mph and 2,800 rpm. Average mpg in hills and on flat is 9.5 towing and 10 when not towing. This setup max's at 21,000 pounds. I don't think that you need a 4.30 diff.
Old Jul 15, 2008 | 11:19 PM
Heavy_Metal
You also have a '06. About 75 more HP and 80 ft.lbs. more TQ.
Get 4.30s. I run 4.56 with 35" tires and 4.30s are great for your application.
Old Jul 16, 2008 | 06:41 PM
newfordrichy
Red face
Oops! Good points, Heavy Metal. That does make a difference.
Old Jul 16, 2008 | 08:37 PM
FordxFour's Avatar
FordxFour
The V-10 and the 4.30's is the perfect towing set-up. I tow the 8500# travel trailer like it's not even back there.
Old Jul 16, 2008 | 09:13 PM
rich250's Avatar
rich250
alright thanks for the input guys,the shop ordered 4:30 gears
Old Jul 17, 2008 | 12:58 AM
Fosters's Avatar
Fosters
just outta curiosity, let us know how much the whole sha-bang runs ya
Old Jul 17, 2008 | 05:13 AM
rich250's Avatar
rich250
the shop did work up a price for me of $1900.00 this includes new seals and bearings in the back rear,just ring and pinion up front unless anything else is needed.the shop doing the job is a very reputable driveshaft and axle shop, that's all they do.I will report back with the exact final tally once the truck is done.
Old Jul 23, 2008 | 08:43 PM
rich250's Avatar
rich250
final tally is $1813.00
Old Jul 23, 2008 | 08:52 PM
FordxFour's Avatar
FordxFour
Now next time you hook up the 8000# TT, you will see that it was money well spent. Also don't forget to change your signature to 4.30.
Old Jul 23, 2008 | 11:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
And let us know how it works out!
