429 Alt relocation
Old Jul 14, 2008 | 08:20 PM
downdeephuskyjerk's Avatar
downdeephuskyjerk
429 Alt relocation
I have a 79 Bronco with a 429 in it from a 73 or 74 Torino. I use the truck off road and in mud/water holes. The alternator is located low on the passenger side, I'd like to raise it up somewhere to keep it from getting to wet.
Old Jul 15, 2008 | 12:44 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
how low? like in line with the water pump low or in line with the crank?
i looked at the L and L setup. its approx inline with the water pump on passenger side
Old Jul 15, 2008 | 03:39 PM
Thunderjet4x4's Avatar
Thunderjet4x4
I don't like the low mounted alt. either-not fun to adjust belt, and too low for muddin. This setup is also a chore to replace the alt. belt. I did however find an 85 F250 4x4 w. 460 at a wrecker that had dual V-belt setup with the alt. mounted just in front of the pass. side valve cover. The mounting brackets are fairly big, but brings the accessories up alot-but it should bolt onto any regular 429/460. The bracketry also has some provisions for an airpump and a/c setup-could be handy to mount an engine driven air compressor.
Myself, I am going to trim off any parts I don't need, should look nice, and won't have to guess too much about belt replacement.
I have seen similar setups in some old lincolns too.
Hope this helps, good luck!
Old Jul 15, 2008 | 07:17 PM
downdeephuskyjerk
Thanks for the replies. Now I have another reason to go to the local salvage yard.
