how to make big hp
Old Jul 13, 2008 | 10:46 PM
fordidiman's Avatar
fordidiman
how to make big hp
Hey there am the new guy .so I have a 1990 ford f350 I have had form day one and I have been saving money to buy a new truck but when I went to go look at new ones I just couldn’t do it. So now I have about 32.000$ to spend on my truck what I need to know is just about everything you can do to this motor to make big power. thanks
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Jul 13, 2008 | 10:57 PM
fordmike1's Avatar
fordmike1
What Engine do you have?
Old Jul 13, 2008 | 10:59 PM
fordidiman's Avatar
fordidiman
1990 7.3 idi
Old Jul 14, 2008 | 01:17 AM
David85's Avatar
David85
You are going to spend $32k on this truck?
Old Jul 14, 2008 | 01:28 AM
fordidiman's Avatar
fordidiman
well not that much but am going to redo the hole thing .
Old Jul 14, 2008 | 01:49 AM
Dodge/Cummins's Avatar
Dodge/Cummins
My kinda' guy! Don't take that how it sounds! LOL!
I'd much rather have an old truck the way I want it than a stock new truck. No question about it.
If you want to make absolute *****-to-the-wall MEGA power swap in a Cummins out of a Dodge from '94-'98.5. It will have the Bosch P7100 Injection pump and if you're a manual trans. guy, it'll have the NV4500 too. That's A LOT harder to do than building your motor and putting it back in.
If your goals are more realistic I would get a 6.9L from '86 or '87, head stud it, 7.3L valves and rockers, 7.3L Turbo rods, pistons and pins and if you don't TURBO it you're crazy. I don't know which one to use solely for POWER but somebody will chime in.
I'm not sure if going with 7.3L heads is better or worse but I GAURANTEE you Dave S. will be on here to tell you every nut and bolt to put in it. His motor has milled pistons to reduce the compression ratio to run more boost from the turbo. You wont get 4-digit hp and trq. #s from these motors like you can a Cummins but that much power is USELESS in the real world.
I'm a HUGE Cummins fan but when my 369K motor gives up I'm building a 6.9L just like I described above.
One thing to check out is if you can install an older model year motor in you truck where you live. Some states and localities demand that you use a same year or newer motor in your vehicle. If that's the case SLEEVE your 7.3L before you build it.
Old Jul 14, 2008 | 01:58 AM
David85's Avatar
David85
The conrods, wrist pins and pistons from a factory turbo IDI 7.3L will not swap over to a 6.9.
But I do agree that the 6.9 with many of the top end parts of a 7.3 will make the best motor.
What tranny do you have? if its auto, it will need internal upgrades to survive what a built up 6.9 can pump out.
Old Jul 14, 2008 | 02:04 AM
fordidiman's Avatar
fordidiman
thanks for the info what do you think about this (Ford Diesel IDI)
Old Jul 14, 2008 | 03:03 AM
Dodge/Cummins
Your probably right about the rods I was thinking about sleeving my 7.3L when that was my plan. Now I have a 6.9L donor so I'll probably use that.
I don't think the 7.3 turbo rods are that much better than the NA version anyway. But are they any better than the 6.9L's? If they don't swap it doesen't really matter but I'd like to know.
I'm a manual trans. nut so I'd go woth the ZF-5spd. for sure.
Old Jul 14, 2008 | 03:12 AM
Dodge/Cummins
As far as the reman motor goes: PERSONALLY if I'm building a "custom" motor I want to be hands-on and build it the way I want it, especially a high-power one.
I would find a GOOD machine shop, not necessarily a "race" shop. REALLY do your homework and get somebody good and reliable and have them do your machine work. If you don't want to build it yourself they might do it for you. That would be opimal, that way the machine shop can't blame the mechanic/assembler and vise-versa.
My Dad owns a machine shop and has been doing motors for close to 40 years so I don't know what the "retail" cost would be, as I've never had to pay it, but I'll bet you could build/have built a motor for around the same price as the reman is and have it built your way too. Make sure you factor in shipping if necessary on the reman as that won't be cheap.
Another thing is: I would worry about the 7.3L reman unless it's been sleeved. You could put it in and 5K later find out your cylinder walls had electrolysis/pitting/cavitation and you have to start over again. I don't know what their warranty is but I'd be hesitant.
I don't know how you could rebuild a 7.3L well without sleeving it because if you bored it out you would have WAY too thin of cylinder walls.
I have a hard time going to the trouble of building/rebuilding a motor without starting with nice straight, round, cross-hatched cylinders, in fact I never have.
My Dad even insists on sleeving 6.9Ls if he's warrantying his work, might or might not be excessively paranoid I don't know.
Old Jul 14, 2008 | 05:17 AM
FORD MEGA CAB!!!'s Avatar
FORD MEGA CAB!!!
How much power is BIG HP. What are you wanting to do with it. Do you want to have a competition type truck for pulling sleads and racing? OR are you just trying to get more power out of ol betsy for pulling trailers and keeping up with the newer trucks (left stock that is)?
I already kinda thought what I would do If I could use 20,000 of my finances. I would
Get the Cummins Conversion Kit
Get a good used Cummins from a wrecked truck
Get the modes you want for that engine
Rebuild that transmission with beefed up components
Redo the interier with fresh carpet, seats redone and any broken/worn/faded pices replaced
If needed, a new paint job
Polish the wheels if they are aluminum and cover them with a good set of tires
Now we have a BAD Truck That would look like it just rolled of the showroom floor.
If you want to stay away from the cummins then your options are limited for big hp. For the engine I would buy the banks trubo sidewinder kit just for that truck (or ats if perfered), replace the head bolts with headstuds and fresh head gaskits so I could run more boost pressure. Im not sure How important milling the pistons are so DAVE S will probably be able to tell you but if possible I would have them milled down a little to lower compression. I would also replace that stoke torque converter and still rebuild the tranny.
Old Jul 14, 2008 | 11:26 AM
fordidiman's Avatar
fordidiman
about 400hp a friend of mine has a 1992 7.3idi that maks about 385hp and i just like the way 400hp sounds .my plans are to make this one hxll of a truck
Old Jul 14, 2008 | 02:40 PM
David85's Avatar
David85
How did he get 385 Hp out of an IDI!?
Old Jul 14, 2008 | 02:57 PM
FORD MEGA CAB!!!
I think he is leaving out critical, need to know information!!! Please share with us!!
Just go over to your friends house, ask a few questions and go from there. How much boost and what internal modes has he done so far. Is he using anything else along with the diesel. Did he do anything to his injection pump and what injector code. How credible was the place that dyno'ed his truck and has he ran it more than once. I think Im only putting out 260 and stock i think is only 175 so another 225 hp would be neet. Also, What rpm is he at when he made the 385 hp on the dyno sheet and do you know his torque was? Sorry about all the questions but now im very interested.
Old Jul 14, 2008 | 04:26 PM
fordidiman's Avatar
fordidiman
well he moved to mississippi so that would be one walk form were am at but he had
7.3 Indirect Injection Engine FROM Diesel Engine Remanufacturing Industry
BANKS SIDEWINDER TURBO KIT
MBRP STAINLESS STELL MUFFLER AND MBRP 4.00’’ POWER TUBE • BANKS E40D TRNSCOMMAND
BD EXHAUST BRAKE
Ford cast aluminum deep pan cooler Trans
Dps High Performance Pump and Fuel Injectors and some other thing all call him to night and find out
