Homebrew fun
Homebrew fun
This is not necessarily related to diesels alone but i thought I'd share with you guys in the 7.3 forum since this is where I typically hang out. Let me know what you think
I decided to make my own parts washer. It's only good for aqueous solutions, but so are most cheap ones from the stores. Here's a basic run down.........
Bar sink drain with strainer
4x toilet tank bolts
fountain pump from harbor freight <$10
tubing
pvc fittings.
vacuum line couplers from an assortment pack I had running around (spray nozzles)
two buckets, one resevoir, the other suspended underneath drain with its bottom turned to swiss cheese with some shop rags in it for basic filters.
Pipe strapping and rivets to secure the fittings.
Tub is a feed trough from a farm supply store.
Chad.
tubing
pvc fittings.
Chad.
honestly I don't know all together I've slept since then. in know the tub was near $30 new. and the fitting's and pipes were near $20. Everything but the buckets I bought. Should give ya some ideas though. If you have things laying around you can put them to good use and get out cheaper than me. I wanted to design one that I didn't have to interact with. Hence the nozzles. Kinda like an automatic dishwasher for parts. There is still a hose for manual application of solution though.
those buckets are from my pool chemicals. so they have threaded tops, which I think makes it easier to open them. the tub is the hard part to find. Wanted something small for easy storage, but large enough to fit some medium sized parts. I think I got pretty close with that. and being steel it shouldn't deform too much. Gonna try some regular out of the bottle degreasers to start, but also want to try some of the aqueous parts solutions out there. the have better rust inhibitors to prevent flash rusting.
on
yeah pump longevity was my concern as well. Ran it for several hours last night to make sure I at least got all my seals right. The pump's are <$10 at the local harbor freight, so replacing it won't be too bad. I wasn't worried about the detergents so much as what they will clean off. But it's a fairly generic design so I can replace the pump with whatever as needed. The drain for the bar sink has a strainer/stopper built in. So the parts can get a shower or a bath if I close it up. Also want to build a lid for it as well as a spray brush.
Chad
Chad
There are products available on the market that will use enzymes instead of solvent to dissolve grease.
I did a quick internet search for something that you could use in your parts washer and came up with this.
It is specifically designed for clearing out greasy sink traps and drains.
But my guess is that it would work just as well as a parts washer.
And I think it would be compatable with your pump too.
TDW Bio-Enzyme Grease Treatment, Grease Fighter, Industrial Strength Detergent - Shaban, Inc.- New Jersey, Greater New York
Northern tool has an aqueous solution that I though I'd give a try. If it trashes the pump, oh well, I'll just replace it with the same or a cheap parts washer pump However I don't know that the cheap parts washer pumps are built any better. They are usually labelled "aqueous solutions only" unless you cough up some money. worth a shot. Monster Parts Wash Concentrate 1 Gallon | Parts Washers Accessories | Northern Tool + Equipment
Chad
Chad
