Fuel pressure
Old Jul 13, 2008 | 09:45 PM
Olddog66's Avatar
Olddog66
Fuel pressure
I’m having issues getting diesel fuel to stop seeping around the lid on my filter. I’m wondering if it would be possible for the pressure regulator to be failing and the bowl pressure is getting too high and the gasket leaks. Could the fuel pump generate enough pressure to cause that?
Old Jul 13, 2008 | 09:52 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I doubt this is happening. Are you sure the gasket/Oring is installed correctly? It can be installed upside down. Another way is to check your fuel pressure with a gauge. They are dog cheap at any farm supply store and good to have.
Old Jul 13, 2008 | 09:53 PM
danskool's Avatar
danskool
Go Bills !
Check oring for nicks and tears.
Hand tight and one full turn with a wrench might stop it.
I doubt it is over pressure.
Old Jul 13, 2008 | 10:05 PM
Olddog66's Avatar
Olddog66
Filter
I put a new filter on and it has a redesigned gasket...flat not beveled. It seemed like a better idea but it seeps just a small amount around the gasket. I used a filter wrench and gave it a turn but I don’t think any tighter will gain me much. I’ll just get some miles out of the filter and go back to the old style. If I run my finger around the lid I get a small amount of fuel on my finger. From what I’ve read about leaking o-rings on the drain I figure I’m safe with just a wet residue. No fuel pooling on the top of the engine etc.
Old Jul 13, 2008 | 10:12 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I believe that the fuel pressure would only drop over time, if something was wrong with the regulator. It's just a ball and a spring. Over time that spring can get weaker and thus hold less pressure in the system, thats why most people shim it up.
Old Jul 13, 2008 | 10:14 PM
megawatt00's Avatar
megawatt00
The new flat gasket needs to be coated in oil and not diesel in order to seal properly. There was a post here recently about this.
Old Jul 13, 2008 | 10:22 PM
Olddog66's Avatar
Olddog66
Yep that was me and it lasted for about a week and started leaking again. If it ain’t leaking something it ain’t a Powerstroke!
Old Jul 13, 2008 | 10:57 PM
PowerstrokeJunkie
Did you try sealing it with diesel to begin with?
BobbyB
Nov 26, 2014 08:14 AM
AlexG21
Mar 2, 2014 07:26 PM
20powerstroke02
Jan 10, 2014 09:41 PM
99StrokeXLT
27
Mar 23, 2013 09:34 PM
raptor131
Jan 20, 2012 11:53 AM
