Sponsored by: Auxito
oil question
Old Jul 15, 2008 | 09:05 PM
73cntry's Avatar
73cntry
I just use Lucus Oil Stabilizer and 5w 20 Castrol GTX in the Ford and it has 78k on it. Had it since new and no oil burning or leaks. To me it's just preference what oil we all use, a long time ago I used Penzoil when I had a different truck and the oil sludged up some so since then I switched to Castrol to all my vehicles.
Old Jul 16, 2008 | 09:37 AM
ryan_fordguy's Avatar
ryan_fordguy
well i just decided that the motorcaft 5w-20 is doing good for me, and i just changed my oil, it burned about a quart, is that pretty normal? I also was using Fram tough guard as a filter, but from what a lot of people have been saying i switched to motorcraft
Old Jul 16, 2008 | 01:25 PM
xtrford's Avatar
xtrford
The motorcraft oil and filters are all that you need....just pour in and drive!
A quart between oil changes is normal.....all engines burn a bit of oil.
Old Jul 16, 2008 | 05:22 PM
MrBSS's Avatar
MrBSS
Synthetic oils were developed to maintain viscosity through a wide range of temperatures. This is still the best, and maybe the only cost justifiable reason to use them. But you won't notice much difference unless it's below zero.
Old Jul 16, 2008 | 06:35 PM
97Handshaker's Avatar
97Handshaker
DO NOT USE FRAM!! they are JUNK!!! I will never use fram again since my airfilter top came off my fram airfilter!!!
i use either mobile 1 synthetic and change it at 5000mi or i use motorcraft oil and change it at 3000mi. i use motorcraft filters regardless.
Old Jul 16, 2008 | 10:13 PM
steve(ill)'s Avatar
steve(ill)
i have used FRAM in every oil and air filter i have use in every car and every truck since 1965. Over 40 years and never a single problem. Use them in the tractor and lawn mower also.
Old Jul 16, 2008 | 10:54 PM
Club Wagon's Avatar
Club Wagon
Motorcraft oil filters are made by Purolator & are highly rated time after time. The Motorcraft item is a good value equal to Purolator's premium filter. Fram's standard oil filter gets relatively lower grades in various comparisons.
I recently was disappointed by Fram's premium $18 air filter. The sealed package described an expanded metal screen used to support the air filter element & showed a picture of just that. The cheaper standard Fram air filter's box wasn't sealed in plastic, looking inside there was no metal screen. Having once had mice chew up an air filter & nearly cause disaster I wanted the metal screen. When I went to install the air filter I found no metal screen!
GAF
Oil & Lubrication
Oct 21, 2007 09:48 PM
Sporty_Ford
2004 - 2008 F150
Dec 21, 2005 04:21 PM
StorminTexan
Oil & Lubrication
46
Aug 30, 2004 03:00 PM
NCF150
1997 - 2003 F150
Dec 30, 2003 10:04 AM
andrewe
Oil & Lubrication
38
Feb 28, 2003 04:40 PM
