need help with shock install
Old Jul 13, 2008 | 03:56 PM
bigsteve1969's Avatar
bigsteve1969
alright prolly gonna do my shocks tomorrow afternoon so any instructions and tips would really help. I have a jack but i dont trust it under that diesel so im gonna try and avoid jacking the rearend also i'll be doing an upgraded sterring stabilizer soo any tips on that would also help out. ha prociate the help guys
Old Jul 13, 2008 | 04:03 PM
ron's power stroke's Avatar
ron's power stroke
no jack needed..turn the front wheel all the way for each side..2 bolts to come out...one at the top..one at the bottm....shock should pull right off but you may need a hammer....slide on new shock and re bolt them nice and tight.. same for the back.....what kind of shocks did you get??
Old Jul 13, 2008 | 04:15 PM
big poppa's Avatar
big poppa
Just what Ron said but I needed the jack for mine for the back so i could get the bolts in the bottom part of the shock. Jacked it up on the hitch a little to eye up the bolt holes then cut the strap compressing the shock. Spray the bolts tonite for a easier install tomorrow. As for the stabilizer, i turned the wheel all the way to the left then installed the bracket and shock so when you turn the wheel the oppisite way it stretches out evenly. Good luck.
Old Jul 13, 2008 | 04:43 PM
PaysonPSD's Avatar
PaysonPSD
Measure the stock shock length before removal. If you are going to jack up vehicle measure shocks after jacking and leave jack at same height. Compress or extend new shocks to that length and tie them up in such a way you can install them tied. A loop over each mounting ring works good. This will make them much easier to install. The new shocks will be a bear to compress and hold. Worked for me. Also, the front nut on the front shocks has a tab on it to hold it while the bolt is turned. If you turn that nut the tab will bend. Just remove the bolt keeping that nut pushed to the rear. Impact wrench works great for all the bolts.
Old Jul 13, 2008 | 05:01 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I did mine (all four) by myself with no jack in a little over an hour. The fronts are super easy. The rears are a little more difficult simply because they are tough to compress if you let them extend all the way. For the rear, I hung the tops first and then muscled them up and caught the hanger with a drift pin. Once that was in I chased the drift pin out with a bolt.
Old Jul 13, 2008 | 05:15 PM
ron's power stroke
if you have a floor jack..you can use that to help install the rear shocks..hang the top..use the jack to push the shock up till the holes match...
Old Jul 13, 2008 | 05:41 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Come on now, some of you guys must have twigs as arms. When i was 15-16 i installed sets of shocks on work trucks, and a few months ago i easily compressed a set of bilsteins. Steady force on the shock, give it 15-20 seconds to compress. Its easier to do it that way than heaving on it and trying to compress it quickly.
Old Jul 13, 2008 | 05:57 PM
Texas Outlaw
Not a liberal...
That's how I did mine, Kris.
Old Jul 13, 2008 | 06:08 PM
PowerstrokeJunkie
Scott back in his younger years...
Old Jul 13, 2008 | 06:12 PM
Texas Outlaw
Not a liberal...
Holy cow!
ron's power stroke
Old Jul 13, 2008 | 06:14 PM
PaysonPSD's Avatar
PaysonPSD
I'm 61 years old and can probably bench press more than you can. With age comes wisdom. I would rather use my brain than my brawn.
Old Jul 13, 2008 | 06:45 PM
big poppa's Avatar
big poppa
I,m with yaa Robin, i only use my muscles when i REALLY need them, lol.
Old Jul 13, 2008 | 07:02 PM
PaysonPSD's Avatar
PaysonPSD
Mind over matter, right?
Old Jul 13, 2008 | 07:14 PM
big poppa's Avatar
big poppa
You got it Robin!!!
