tire treatment
Old Jul 12, 2008 | 06:26 PM
aurgathor's Avatar
aurgathor
tire treatment
Is there any rubber/tire treatment that could be used to prevent UV and ozone damage, plus it can protect against the drying out of tires when they see little use, like on a trailer? Or off, and in a plastic bag.
TIA
Old Jul 12, 2008 | 06:39 PM
Steina's Avatar
Steina
CO River Rat
303 works pretty well; doesn't make the tires shiney, but that's why I like it.
Steve
Old Jul 12, 2008 | 08:23 PM
maevans's Avatar
maevans
Here's another option - Sunblock For Tires - Camping World
Old Jul 12, 2008 | 10:05 PM
F350-6's Avatar
F350-6
How long are your tires lasting without the treatment? I had a blow out today on a tire about 6 years old that had now sidewall rot visible, but still blew a nice size chuck out of the side.
Old Jul 12, 2008 | 11:19 PM
aurgathor's Avatar
aurgathor
The tires are from my Bronco (LT235/75R15C), about 5 - 6 years old with about 30% thread left, and I want to put them on a 1740lbs utility trailer so that:
a) I don't need a separate spare for the trailer
b) the trailer will have a similar ground clearance
Since a single tire is rated more (1985 lbs) than the trailer is rated for, I think they should last for quite a while and I don't need to worry much about blowouts, especially since they probably spend ~48 weeks/year in a plastic bag.
Old Jul 12, 2008 | 11:27 PM
F350-6's Avatar
F350-6
The spare tire that matches the truck and trailer is a great idea. Unfortunately, most hubs match a chevy bolt pattern. Have you verified the spare will fit the hub?
It's not always the weight that causes the blow out. I've had more tires fail running a trailer empty (like today) than when they're loaded.
Old Jul 13, 2008 | 12:46 AM
aurgathor's Avatar
aurgathor
I know it won't (4 bolt 12" wheel right nowl) but I have a spare 8.8" rear for now; eventually, I plan to get a trailer axle and two 5x5.5" hubs.
Interesting. I wouldn't expect that, but I guess it isn't as bad if it were fully loaded.
Old Jul 16, 2008 | 02:23 AM
aurgathor's Avatar
aurgathor
What is a "303"? Who sells it?
I went to Schuck's today, all they had is those crappy "wet look" treatments with silicone oil.
Wal-Mart: almost the same thing, but they had one matte one, only problem with that I couldn't read the fine print on the bottle.
Seems to me these treatments are mostly for beauty queens....
Old Jul 16, 2008 | 10:19 AM
Steina's Avatar
Steina
CO River Rat
Here's info on buying "303": 303 Products, Inc. Makers of 303 Aerospace Protectant, High Tech Fabric Guard, Patio Furniture Cleaner and More !
Steve
Old Jul 16, 2008 | 04:57 PM
rclarke's Avatar
rclarke
No matter what kind of treatment or storage options, after 5 years from the date of manufacture your tires are on borrowed time and can blow out at any time.
Old Jul 16, 2008 | 07:16 PM
newfordrichy's Avatar
newfordrichy
RClarke is correct. I read that recently.
Old Jul 17, 2008 | 12:57 AM
aurgathor's Avatar
aurgathor
Can they blow? Yes. Is it likely? No. At least not for another 5 - 10 years.
