2 piece drive shaft conversion
Old Jul 12, 2008 | 10:58 AM
gearhed1971's Avatar
gearhed1971
I have a basically a '73 f100,but on a '72 frame.I have a 2 piece drive shaft and would like to change to a straight shaft.Does anyone have any tips for an easy conversion?
Old Jul 12, 2008 | 03:55 PM
gearhed1971
Also,I am running a 4 speed man.,with a 78 bronco rear end
Old Jul 12, 2008 | 04:37 PM
84-250's Avatar
84-250
The reason for two piece driveshafts is because the truck is too long for a single shaft or there is no slip yoke at the trans. If your trans has a fixed yoke you're pretty much tied to the two piece. I dont know if there are any manual trans with a slip yoke instead of a fixed yoke.
Old Jul 12, 2008 | 07:08 PM
85e150's Avatar
85e150
Even if your two piece needs repair, stick with it. The driveshaft whip and vibrations you invite with a long shaft will make you wish you hadn't changed.
Old Jul 13, 2008 | 09:06 AM
gearhed1971
I see a lot of higher power trucks at pulls blow out what looks to be the front part of the shaft.How will that setup hold out when I add another 100+ hp?
Old Jul 13, 2008 | 09:09 AM
gearhed1971
Also my 77 with a three speed had a straight shaft,but different length to the rear end.No shake problems,but only a straight 6 300
Old Jul 14, 2008 | 01:48 AM
85e150's Avatar
85e150
100 horse on top of what? Any stock motor? No problem.
You may or may not have whip/vibration issues. Since there does not appear to be anything to be gained by changing, why invite those issues and expenses?
Old Jul 30, 2008 | 12:27 AM
79F1504X4a's Avatar
79F1504X4a
2-piece driveshafts reduce stress on the universal joints.
When the angle between the transmission and rear axle is too severe, a two-piece shaft cuts down on the flexing/stress on the u-joints, ergo, less u-joint stress and failure. As a previous poster sugessted, stick with the 2-piece. Manufacturers are cheap, if they could get by with a single shaft, no center-hanger, and one less u-joint, they woulda done it.
