I have a 1989 5.0L Bronco Eddie Bauer, and i had A/C and everything, but now if i ever put a new fuse in it will just blow, so i cant use anything including my defroster, can anyone help.
Thanks.
Assuming you are blowing the A/C, heater fuse,(no.9) here is the path to follow. You have a short to ground on a wire in that circuit. Possibilities are blower motor, clutch pressure cycling switch wiring, a/c clutch field coil, blower resistor wiring, blower switch wiring, and a/c heater function selector switch or any wiring in this circuit.
