Stereo Upgrade -- Ford CD6 w/ MP3
#46
#47
#48
Hey I've got a question for anybody that might know. I've got a 2007 escape with the 6cd changer radio part number 6L8T-18C815-DD. It says it's got and aux in for an iPod but I don't see a cable for it. Tried looking in the back of the radio for an input but only found the snake of cables. Does anybody know which color cables is the aux or where to find a wiring diagram for this radio. Thanks
#49
I replaced my base model single CD player with a touchscreen Radio/GPS/DVD/MP3/Bluetooth unit for my '06 F350XLT. It is an off-brand I bought off eBay for around $200. I also had to pick up a wiring harness and a dash adapter from Autozone for $20.
Took about 20 minutes to pull the dash and extract the old head unit and another 10 to wire the harness. The roadblock was trimming the dash adapter. The i.d. was about 1/4" too small. I used a dremmel and an emery board to trim the opening, another 20 minutes.
Everything bolted right up the first time. No adjustment needed on the dash depth. I routed the GPS antennae coax thru a small gap at the defroster vent.
I have the option of adding a backup cam and that will be coming, along with installing my CB, after I get a new toolbox/fuel tank combo.
Here's the results:
Not bad for less than $250 and about an hour of effort on a Sunday afternoon.
(Before you say anything, the DVD is disabled when the truck is in motion.)
Here's the results:
#51
#52
6L8T-18C815-DD is listed as 2005-2006.5 MY Escape/Mariner. Features are listed as "Visteon Z series CD6 premium w/MP3 & AVC. Sat Compatible." That model also has the WWC (Worldwide) plug which should be plug compatible through about model year 2003 or 2004 in most Fords. Beginning in either 2004 or 2005 they changed the plug to the one called "phase II". This requires an adapter plug which costs about $30.00 in order to install in the earlier models. The radio that you have should be a direct "plug and play", no adapter required for your truck. All Fords did not change to the newer plug on all radios on the same model year. Also the 2005 and later Super Duty radios will not fit in the earlier model Super Dutys, but the 2007 Escape radio will. It is model # 6L8T-18C815-FD. It is listed as "Visteon CD6 audiophile w/MP3 & AVC. Sat compatible." I like the audiophile model because it has the "high power", RDS, (displays station type, song name, artist name, etc.), lets you scan by song type, etc, etc. As always, it depends on what you like. Both of the radio models listed above look identical from the front, but the plugs on the back are different. The audiophile model supports the external sub-woofer. I am not sure that the other one does.
#53
O SEA D
05-30-2010 03:33 AM
-*o*- REWASDRTY
1999 to 2016 Super Duty
15
03-01-2010 05:08 PM
