Help Fixing my work Horse
Old Jul 11, 2008 | 05:17 PM
JTufts's Avatar
JTufts
well my 1995 ford f-250 4x4 351 **** the bed about a year ago
we swapped in a 351 from a junk yard truck but we used our 1995's harnes and wiring cause it was a hell of alot in better condition
now the engine stars but its running RICH the EGR needs to be replaced and i am doing that soon
but first things first , did ANYTHING change from 95 to 96 in the wiring that would make the 95's harness not work ? does any one have any HQ images of there stock engine bays by chance so i can compare whats ran were ?
Old Jul 11, 2008 | 05:29 PM
danr1's Avatar
danr1
Might be a lot of difference, both half ton? both 3/4 ton? One 1/2 one 3/4? if the 96 is a 3/4ton is it over 8500# GVWR?
Need the exact info for each truck.
Old Jul 11, 2008 | 06:15 PM
Kemicalburns's Avatar
Kemicalburns
nothing is different the motors are the same. the difference would be the efi system, the distributor and the emissions but if you borrowed parts from your 95 5.8 and placed them onto the 96 5.8 you should be in good shape.
if its running rich i wouldnt suspect the egr as the problem. should look at the basics like tune up, timing and fuel pressure. might need an o2 sensor replacement. Ford Fuel Injection has instructions for testing all this and pulling codes.
Old Jul 11, 2008 | 07:29 PM
danr1's Avatar
danr1
No the motors are the same, I was thinking more about any sensors used that may be different.
Speed density verses mass air flow or more to of a issue obd1 3/4 ton to 96 half ton with obd2 sensors mixed in perhaps.
Old Jul 11, 2008 | 10:25 PM
JTufts's Avatar
JTufts
do you know the location of the o2 sensor on this 96's engine i no longer have the 95 in my position so i cant get the parts unless i get em from the junk yard
and even then they might not part it out unless the engines blow junk yards around here are *** holes
Old Jul 12, 2008 | 11:48 AM
JTufts's Avatar
JTufts
any one know were the O2 sensor is ? i dont have a little handy dandy note book around
Old Jul 12, 2008 | 12:14 PM
alz's Avatar
alz
Was this 96 engine out of a F150 or larger(F250/350)? F150 would be OBD2 using two O2 sensors. Not sure, but would think one would be in the y-pipe and other after cat. Or maybe both are in the y-pipe, one on either side.
Old Jul 13, 2008 | 01:59 AM
JTufts's Avatar
JTufts
250 as far as i was told but how does running rich have to do with my exhaust pipes sensor ..
Old Jul 13, 2008 | 05:43 AM
netscaner's Avatar
netscaner
The O2 sensor in the pipe senses the amount of spent or unspent oxygen in the exaust and reports it to the computer which then adjusts the mixture through pulses to the fuel injectors.
Old Jul 13, 2008 | 11:00 AM
JTufts's Avatar
JTufts
see that i understand i just didnt know what an o2 sensor did
