Charge light flickers intermittently
Old Jul 11, 2008 | 10:58 AM
Wahoo121's Avatar
Wahoo121
My 01 5.4L charge light flickers intermittently at approx. 2000 rpm the charge light comes on and then goes off at approx. 2200 *or* 2400 rpm.
I replaced the belt thinking it might be slipping, but it continues to come on. The belt tensioner seems all right, How do you check them? It still takes a 24 inch breaker bar to move it. While I had the belt off I took the alternator to NAPA and had them bench test it, it tested ok. The battery is 2 months old.
Any ideas?
Old Jul 11, 2008 | 01:15 PM
04markIII's Avatar
04markIII
loose connection?
Old Jul 11, 2008 | 01:50 PM
cbradford's Avatar
cbradford
Have your alternator tested as it could be internal which also contains your voltage regulator, I had an issue with my 97 which had 1/2 of the full wave rectifier burned out.
Old Jul 11, 2008 | 02:08 PM
04markIII's Avatar
04markIII
he had it bench tested at a local napa, but maybe it would read/react different say if someone tested it on the vehicle?
Old Jul 11, 2008 | 02:41 PM
Wahoo121's Avatar
Wahoo121
I was wondering if there could be a difference between bench testing and on the vehicle testing. I'll find out. As far as loose connection I haven't found any, but there could be one I am missing.
Old Jul 18, 2008 | 11:02 AM
Wahoo121's Avatar
Wahoo121
Well, I took it to a local repair shop. They tested it in the vehicle for $20. Sure enough the voltage regulator was intermittently bad. Back to NAPA for new alternator, problem solved. Guess that proves bench testing is always effective. They can't get the rpm high enough.
One question, in the alternator box was some dielectric grease. First time I was ever given that. I assume it's for the two small wires. My repair manual says nothing about using it. Should I ?
Old Jul 18, 2008 | 11:03 AM
Wahoo121's Avatar
Wahoo121
Should read bench testing isn't always effective.
Old Jul 21, 2008 | 11:41 AM
heterodox1's Avatar
heterodox1
I think it's wonderful that these alternators die this way. Same thing happened to my buddy and I've read multiple posts about an intermittent alternator light just prior to the alternator quitting completely. I wish every component gave us warnings like this.
The dielectric grease is to smear all over the connectors before putting them together - it will help keep a good connection by keeping moisture out.
1981fordstepside
Jun 21, 2014 01:11 PM
highoctane74
Oct 14, 2013 12:44 PM
12valveEx
Aug 16, 2013 08:24 PM
zeus77
Jun 8, 2012 03:28 PM
weathers1200
Jul 20, 2009 03:40 PM
