6.9L Starter Removal Question
Old Jul 13, 2008 | 10:42 PM
gov2mod's Avatar
gov2mod
How do you get the top bolt finger tight if you can't get your fingers on it?
Old Jul 14, 2008 | 12:53 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Archangel's way is the way I did it the 4-5times I took mine off and on right after I bought it.
I still used an air ratchet too, I just made the extension exactly the right length instead of too long like the first time.
Old Jul 14, 2008 | 03:24 PM
archangel's Avatar
archangel
This one is too easy!!!!!
You did know you can you use a socket and extension to get something "finger tight" without using a ratchet, right?
I can, and have, used a 4' long extension and get something "finger tight" and never get closer than 4' from it!
If you know any mechanics, ask them.
Or better yet, barrow a socket and extension and try it for your self.
I said "finger tight' as in "finger torque" or "as had as you can just using your fingers as a turning force.
I did not say "with my fingers on the bolt head".
It's not "read, type, think.
It's "read, think, type!
OK, I'll stop now.........
Old Jul 15, 2008 | 01:37 AM
84-6.9's Avatar
84-6.9
The reason I had to tip the nose of the starter down was after i couldn't back the top bolt all the way out because the socket hit the starter case. and after i hung the starter on the bottom two bolts (i forgrot to say this) i lifted the starter up and put the top bolt in by reaching behind the inner fender and over the frame rail and got the bolt started. Then I let the starter drop so i had clearance to get the socket on it. Mine is a direct drive starter so I'm not fimiliar with the gear reduction ones.
johnday
2009 - 2014 F150
Jul 22, 2017 08:09 PM
twack
Jan 16, 2017 02:05 PM
bama29fan
28
Apr 25, 2011 12:10 PM
alconk
15
Oct 9, 2008 09:30 PM
Josh79
13
Jan 18, 2004 05:13 AM
