Boost!
Old Jul 10, 2008 | 01:01 AM
MallardSlayer07's Avatar
MallardSlayer07
Boost!
I have the stage 1 - 160cc injectors on my stock turbo with fpr shimmed a pro guard seven afe filter with a super duty intake that i rigged up. I took a dremmel tool to the ccv housing and rounded it out. Rerouted my ccv under my truck to the back so it can breath. I have a OBD plug in Stuperchip programmer on there on High Performance. Stock dp (i knw biggest downfall right now) stock straight pipe exhaust and i think that about sums it up. HONESTLY: I build 30 pounds of boost dead even when i got er wound up. IS THIS NORMAL?
Old Jul 10, 2008 | 06:53 AM
fishmanndotcom's Avatar
fishmanndotcom
sounds about right to me. i have a similar setup and when wound up i can hit 32lbs pretty easy! thats one reason i swapped on a D66... to take the pressures the stocker couildnt handle
-cutts-
Old Jul 10, 2008 | 12:35 PM
MallardSlayer07
-cutts-
Ok thats good to knw. I could prolly hit 32 but i run out of oil with the stock HPOP lol.
Old Jul 10, 2008 | 12:41 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Mallard, I've got exactly the same problem. Been lookin' for a 17* HPOP, but think I'll have to find cash first. Those are the same numbers I'm gettting too.
Old Jul 10, 2008 | 12:43 PM
MallardSlayer07
Just for kickers i have a stock dp, what does your truck run as far as EGT's on the road at like 70 or so or any other numbers you can give me as far as speed and EGT's go? I think i cruise around 775 at 70 i think?
Old Jul 10, 2008 | 12:47 PM
Fullcrew7.3
That seems about right. and with about 4 pounds boost. Mind you, since I put the 36" ers out back, my revs and boost at cruising speed have been lower. EGT about the same though.
Old Jul 10, 2008 | 01:14 PM
MallardSlayer07
Gotcha ok sounds good. I am going to switch turbo's before too long to the hypermax setup. I already got the turbo just waitin on the piping for it.
Old Jul 10, 2008 | 09:50 PM
mchildress's Avatar
mchildress
Sorry chris for interupting!!
Fishman how do you like your d66, what can it hanndle boost, and what not.
Old Jul 11, 2008 | 05:56 AM
fishmanndotcom
well its good to 40lbs and i never take mine over 30 if i can help it. i did notice a power upgrade when i swapped it on which is nice but my biggest differenece i noticed was EGT's. i noticed a nice 100* or so drop in temps b/c the D66 flows that much more air.
i would recommend it to those even with stock trucks. aside from being slightly pricey, the piece of mind was well worth it!
-cutts-
Old Jul 11, 2008 | 09:09 AM
wmiller's Avatar
wmiller
Not to hijack but how much boost can we hold with out head studs?
Old Jul 11, 2008 | 10:54 AM
secondarychaos's Avatar
secondarychaos
well, the magic number seems to be about 40lbs. i personally wouldnt go over about 35 without headstuds and firerings.
Old Jul 17, 2008 | 01:13 AM
strokin'_tatsch's Avatar
strokin'_tatsch
MallardSlayer07, i have the exact same set up as you except i don't have a ccv mod and i'm using an edge evolution, not a superchip.. i can't get mine to wind up to 30 psi of boost!!!!! mine will get up to 28 psi at around 27-2800 rpm's and stay there even if i take it up to 3200 rpm's. i just don't get why i can't get it to pull 30 psi.
Old Jul 17, 2008 | 08:33 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
my poor little turbo got subjected to 40 psi quite frequently on my 97 with baby swamps...it started making funny noises
Old Jul 17, 2008 | 05:47 PM
my79f's Avatar
my79f
travis disconnect your wastegate. that might help.
or not hahahaha you dont even have one.
Old Jul 17, 2008 | 06:16 PM
RubberDuck's Avatar
RubberDuck
Austin..........our trucks don't have waste gates.
