Sponsored by: Real Truck
emergency brake adjustment
Old Jul 9, 2008 | 08:41 PM
whiteywhip's Avatar
whiteywhip
i have a 99 f-350 , which i bought recently and either the calibers are froze up in the rear or the cable looks too tight.....is there any adjustment ....every place i looked it seems to be none.....on my old 1988 i could adjust it where the 2 rear cables joined the 1....am i missing something or cut the 1 main cable and add a turnbuckle
Old Jul 9, 2008 | 09:09 PM
highland61's Avatar
highland61
Manual adjustment only...
  1. NOTE: Make sure that the parking brake is fully released.
    With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02.
  1. Remove the brake adjusting hole cover from the backing plate.
    1. Turn the brake adjuster screw to expand the parking brake shoe and linings until they drag against the drum-in-hat brake disc.
    1. Back off the brake adjuster screw until no drag is evident.
    1. Install the brake adjusting hole cover into the backing plate.
    Old Jul 9, 2008 | 09:13 PM
    F350-6's Avatar
    F350-6
    highland61 has the right info. Your E-brake is actually a small drum brake in the middle of the rotor. It can be adjusted just like an old fashioned drum brake. Remove the rubber plug pictured above and use a screwdriver or brake adjustment tool to spin the wheel.
    Old Jul 10, 2008 | 07:26 PM
    whiteywhip's Avatar
    whiteywhip
    wow that is simple....i will check it out....thanks guys
    Old Jul 12, 2008 | 08:18 PM
    whiteywhip's Avatar
    whiteywhip
    ok just fix my truck...turns out the calipers were locked up.....bought loaded calipers....was a great thing...never bought them loaded....it was too easy...looked at the emergency brake shoes..looked good.....wheels turning freely now...all fixed.....
    thanks guys for your help
    Old Jul 12, 2008 | 08:48 PM
    NorCalBusa's Avatar
    NorCalBusa
    Oh- you meant the parking brake.
    Old Jul 12, 2008 | 10:07 PM
    whiteywhip's Avatar
    whiteywhip
    same thing right....when you park...its a parking brake....but if you lose your brakes its the emergency brakes....haha
    Old Jul 13, 2008 | 10:26 AM
    NorCalBusa's Avatar
    NorCalBusa
    I saw the title and it made me think you needed an "emergency, brake adjustment" as in; urgent, important, critical! LOL
    Old Feb 14, 2010 | 01:31 AM
    wolfgar27's Avatar
    wolfgar27
    Question
    with the E brake out of adjustment , would it feel as though you were dragging a heavy load and burn up alot of fuel?
    Old Feb 14, 2010 | 03:30 AM
    _Rick_'s Avatar
    _Rick_
    Wolf,
    It could affect your mileage if it's adjusted too tight or seized in the engaged position. It would eventually wear to the point of it not dragging, but chances are you would notice it before it got to that point.
    - Jack the rear up and get it onto blocks (blocking the front wheels of course).
    - E-brake OFF and transmission in nuetral.
    - Turn the rear wheels by hand feeling for drag.
    Not 100% fool proof, but it's a good starting point.
    If it turns out you do find drag in one or both rear wheels it's more than likely either going to be seized E-Brake shoes or the caliper pins.
    Rick...
    Old Feb 14, 2010 | 12:38 PM
    wolfgar27's Avatar
    wolfgar27
    it's going into the dealer tomorrow for some recall work. I'll have to have them check it. thank you.
    Old Feb 14, 2010 | 06:33 PM
    RentAMan's Avatar
    RentAMan
    Talking E brakes
    Recall on the E brake cables.
    If you experience problems, rebuild the whole assembly behind the rotors & make sure that you clean & lubricate all the moving parts real good.
    I am sure that you have plenty of miles on the truck being a 1999.
    Its an easy & quick way to prevent future problems from occuring.
    Old Nov 18, 2010 | 05:38 PM
    redd2001's Avatar
    redd2001
    er brake 2005 f250
    can you please repost the pics. Do the rotors have to come off to adjust the brake
    Redd Mcintyre
    Old Aug 15, 2012 | 08:15 AM
    Firedog2354's Avatar
    Firedog2354
    It can be adjusted just like an old fashioned drum brake. Remove the rubber plug on inside backing plate near the bottom and use a screwdriver or brake adjustment tool to spin the wheel.
    Old Jun 18, 2017 | 08:34 AM
    Ryan Swinemar's Avatar
    Ryan Swinemar
    Good Morning
    will this also work on my 03 ford f 250 ?. To adjust my park brake shoe ?.
    Thanks
    Ryan
