I have a 1990 F250 with a 460 cu inch engine. I can buy a 1990 full size Bronco for a $150 that is akmost junk. Doors , fenders , tranny and transfer case are good and it has air. The thing has a 302. Will the air bolt into my F250? Will i need any other brackets or anything else to make this work.
padutch
Did your truck have factory a/c on it to begin with?
The answer to that is NO it did not. Does this cause a problem? I sat the 2 viheicles side by side and it does look like everything will bolt right in. Is there something I am missing?
The only problem i can see is that I have an automatic so it has a tranny cooler and also an oil cooler that I will have to work around.
Tell me more.
Padutch
