power
Old Jun 6, 2002 | 07:51 PM
padutch's Avatar
padutch
power
1990 F250 AC I have power to the dryer but none at the compressor. Jumped the plug at the dryer still nothing. Hot wired the compressor and it runs. Other then a bad wire what could it be?
I have a Haynes Book here with thier wire diagram in. From what i can tell the hot wire goes from the preasure switch to a clutch resister diode and then to the compressor. So two questions: Where can I look for this diode and the second do i really need it or can i run the wire from the preassure switch to the compressor. Bet you get a laugh out of that one.
Rick
Old Jun 11, 2002 | 08:03 PM
Bronco894x4's Avatar
Bronco894x4
power
Have you checked your control panel? Maybe bad contacts in it?Bronco894x4
Old Jun 12, 2002 | 12:37 PM
mantta's Avatar
mantta
power
Follow your wires out, somewhere after the low pressure switch on your drier there is a clutch resistor diode. It is in the circuit between the pressure cutout switch and the compressor clutch. That sounds like the culprit.
Old Jun 12, 2002 | 02:57 PM
Thudpucker's Avatar
Thudpucker
power
jrekucki
Jun 4, 2013 07:55 AM
reaydanny
1997 - 2003 F150
Jul 16, 2012 05:37 AM
CaptainIPSC
May 9, 2010 08:28 AM
treetop
Nov 17, 2005 09:25 PM
dugal
Apr 9, 2001 05:56 AM
