351C running rough over idle
Old Jul 8, 2008 | 12:15 AM
OzFTrucker's Avatar
OzFTrucker
Hi guys the 351C in my 75 F350 is driving me nuts. I rebuilt the engine about 18months ago and haven't used it much until now and it isn't running very nice. It runs a 600 vacuum secondary Holley and has an HEI distributor from a Falcon(aussie). The engine idles nice with 17lbs of vacuum but as soon as you start to raise the revs it begins to stagger and break down but if you give the throttle a quick stab it doesn't break down. I was starting to think maybe the coil but I would have thought that if it was the coil it would also break down when you stabbed the throttle. Any thoughts?
Old Jul 8, 2008 | 08:08 AM
effie351's Avatar
effie351
G'day OZ
Nothing as dumb as blocked/small primary jets?
Runs on idle circuit and when you stab it, it runs on accelerator pump and secondarys?????
Just an idea
Mike
Old Jul 8, 2008 | 02:54 PM
80broncoman's Avatar
80broncoman
Try unhooking the vacum advance hose. The wires that go from the coil in the cap to the magnetic pickup can break and the wire insulation look just fine. This will make sure the plate that the pickup bolt won't move.
If you have a tach it will bounce around a lot if the wire are breaking down.
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
LARIAT 85
20
Nov 10, 2011 07:11 PM
LARIAT 85
Nov 5, 2011 07:44 AM
balingwire
Sep 14, 2007 04:17 PM
JBronco
1978 - 1996 Big Bronco
Aug 7, 2006 09:24 PM
