1978 - 1996 Big Bronco
Bronco Engine Question
Old Jul 7, 2008 | 11:48 AM
derty2009's Avatar
derty2009
Cool Bronco Engine Question
I have a 1995 Bronco with a 302 and lately it has been lacking power badly. At idle it sounds completly fine but when you hit the throttle is sounds like it is sucking a ton of air. It still idles and runs fine it just lacks lots of power and i dont know the problem. Please help!
Old Jul 7, 2008 | 11:59 AM
NWBronco's Avatar
NWBronco
How is the water temp? If it is truly getting too much air, it's running lean. Pulling the codes will help diagnose.
Bob
Old Jul 7, 2008 | 12:02 PM
derty2009's Avatar
derty2009
The water temp is fine it probably runs abit cooler then it should even. I pulled the codes and it read out some improper EGr flow code which was due to a bum sensor on the egr. But it runs like crap and it seems more rich then lean. It is extremely lopud when you get on it, it seems like it is pulling air hard from somewhere
Old Jul 7, 2008 | 12:05 PM
NWBronco's Avatar
NWBronco
The EGR condition can cause what you are experiencing. If te EGR system is not functionong correctly, it will dog your idle, and performance.
Old Jul 7, 2008 | 12:07 PM
derty2009's Avatar
derty2009
It idles and runs fine though it is almost like something is putting a drag on the engine.
Old Jul 7, 2008 | 12:08 PM
derty2009's Avatar
derty2009
It is Blowing some smoke but not badly but tell me about your problem i think it might be something about backpressure
Old Jul 7, 2008 | 12:21 PM
derty2009's Avatar
derty2009
ok well my truck has a single pipe system but doesnt have a muffler and just ends after the second stock cat. Could this be caused by an exhaust leak where the donut is on the manifold
Old Jul 7, 2008 | 12:31 PM
Conanski's Avatar
Conanski
When you hit the gas does it sounds like air escaping from a tire? If so you have a broken cat, replace or remove it.
Old Jul 7, 2008 | 12:33 PM
derty2009's Avatar
derty2009
Yeah thats what it sounds like but what do you mean by i have a broken cat? what is broken about it
Old Jul 7, 2008 | 12:58 PM
derty2009's Avatar
derty2009
Will that solve my power loss issure also?
Old Jul 7, 2008 | 04:02 PM
derty2009's Avatar
derty2009
OK well thats what I am going to do I live in minnesota so they dont really care about emissions
Old Jul 7, 2008 | 04:06 PM
Goodsath's Avatar
Goodsath
The clogged cat will restrict air flow and rob your power. A quick check is to unbolt your manifold/header from your pipe and drive it. It does sound like a cat issue, good luck.
