Can my truck handle a piano?
The bed yes, tailgate... I wouldn't.
Question is can the piano handle the truck? I'd wrap it in plastic, then heavy quilts. Put a sheet of heavy plywood on the bed so it stays flat to the floor. Don't let it stay outside long cause the humidity is murder on the state of tune.
How far you gotta' go?
Good luck
Good luck
The piano is at my aunts in Victoria and I have to bring it over on the ferry to the mainland. Probably 45KMs driving but about 3-31/2 hours of time in the back including the ferry ride.
I'd definitely put a sheet of plywood down as the rails for my 5th wheel hitch are in the way. I'm guessing that the secret is enough strong backs to lift it up and past the tailgate...hmmm...
The average (pine or walnut) upright piano weighs around 500 lbs. (550 lbs. for oak).
Add another 150 lbs. if it's a player piano.
Loading: You do not want the piano's weight on the tailgate, so unhook the two straps, and let the tailgate drop all the way down till it touches the bumper.
Put a 5 foot long heavy quilt or blanket on the edge of the bed, load the piano onto it and slide it in. It takes a minimum of two ppl to do this.
Make sure the "belly board" is secure. Run straps horizontally all the way around the girth of the piano in several places (above and below the keyboard), then tie it down.
Thanks for all of the replies guys. I'm going to go and pick it up on Saturday and will follow the advice of taking off the tailgate prior to loading. A buddy has a piano skid so we'll use that.
Anybody from the Victoria area feel like damaging their back for a complete stranger? ...Anyone? ...Bueller?
