Highboy?
Old Jul 6, 2008 | 10:51 AM
SpdBoss's Avatar
SpdBoss
Highboy?
whats a highboy guys? i'm new to these years and this body style so i'm still learning.....
thanks.
Old Jul 6, 2008 | 11:04 AM
Dr. Dirt's Avatar
Dr. Dirt
first "Highboy" or "HiBoy" is an unofficial term. it is a pre 1973 F250 to 1977.5 F250 that was 4x4. it came with a factory 4 inch lift.
oh and since I see that you are fairly new to FTE, welcome!
Old Jul 6, 2008 | 11:30 AM
ihateminimumwage's Avatar
ihateminimumwage
Welcome to the site. If you try the 'Search' function, you'll find a TON of postings on this subject.
Here's the last one I saw:
https://www.ford-trucks.com/forums/7...ml#post6073162
and here's your answer:
Originally Posted by ihateminimumwage
There are a TON of posts on the subject. It's loosely used for the 73-77 4x4 F250s, but the term actually is meant to tell the difference between the 77 & 77.5 trucks. The latter of which has the negative arch leaf springs, making it sit around 4 inches lower.
It not being a factory term, it's all open to interpretation, but the folks who have a TRUE highboy (early 77 F250 4x4) are very particular about what is called a highboy. The term couldn't have existed until the 77.5 trucks came around, as everything beforehand was just a 4x4 F250. The bump-side (67-72) trucks have no involvement in the highboy/lowboy talk.
Highboy is used many times as a selling point for old 4x4 Fords. The same as the 351m becomes a Cleveland and the 360 is suddenly a 390 at selling time.
Old Jul 6, 2008 | 11:39 AM
Scolesy8's Avatar
Scolesy8
two other things different about hiboys is that the transfer case is divorced from the transmission, and that the frame rails are narrower, approx. 34in wide....which i have found to be a pain for finding headers to fit
Old Jul 6, 2008 | 12:26 PM
montana_highboy's Avatar
montana_highboy
thanks.
The most simple answer i give people is if it has 3 drive shafts underneath, it's a highboy.
Old Jul 6, 2008 | 01:36 PM
SpdBoss's Avatar
SpdBoss
thanks guys for clarifying that up for me......i'm alittle smarter now about these things. lol
Old Jul 6, 2008 | 02:48 PM
150ford's Avatar
150ford
Yah dont be afraid to ask questions. These guys are the greatest. Welcome again.
Old Jul 6, 2008 | 03:27 PM
F250army45d's Avatar
F250army45d
67-77.5 F250 4wds that were taller than typical trucks in that era were considered HIGHBOY'S why because they sat higher then other models. Typical of the HIGHBOY was a gas tank behind the seat, Narrower frame rails, Divorced transfer thus giving it three drive shafts, front spring hanger is a crossmember style, has 6 ply spring packs 3 wide, Rear springs 2.5 wide and 9 ply. All I can think of.
The statement that they only refer to 73 to 77.5 is not true I know some friends in TX that call there 70 F250 and 72 F250 HIGHBOY's and get mad when you consider only the 73 77's as HIGHBOY'S
Welcome!!!!
Old Jul 6, 2008 | 03:43 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
The frame shouldnt get any narrower until behind the cab. Reguar headers fit fine. I didnt have any prob on my highboy
Old Jul 6, 2008 | 04:25 PM
Dr. Dirt's Avatar
Dr. Dirt
I didn't say 73 to 77.5. I said pre 73 to 77.5.
Old Jul 6, 2008 | 04:28 PM
bucks77ford's Avatar
bucks77ford
Which would mean 67-77.5
Old Jul 6, 2008 | 05:08 PM
F250army45d
It's loosely used for the 73-77 4x4 F250s from post #3 in this forum!!!!
And I also got headers on mine with a little bit of work.
Old Jul 6, 2008 | 05:22 PM
Dr. Dirt's Avatar
Dr. Dirt
thanks a lot Buck
Old Jul 6, 2008 | 05:24 PM
Dr. Dirt's Avatar
Dr. Dirt
thanks a lot Buck.
Old Jul 6, 2008 | 06:28 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
thanks a lot Buck.
There are 65-66 trucks that can be classified as Highboys as well.
The 1973-1977 F-250 4x4 share the same frame width with the 67-72 models for one. One of the reasons the Factory main gas tank is in the cab for all highboys.
