IDM Mod Impressions
Old Jul 6, 2008 | 10:04 AM
Zephyr's Avatar
Zephyr
IDM Mod Impressions
I followed Cookie88's directions https://www.ford-trucks.com/forums/7...-pictures.html
& modified my own IDM.
1. Throttle response improved noticeably, it was already good with the 80e tune, but got even better after the mod.
2. Overall it feels like its making more power but thats just a seat of the pants meter.
3. After 4 tanks full of fuel, my mpg (mixed driving avg, hand calculated) improved from 15.6 too 16.8.
All in all, worth the $6 I spent for the resistors & the 3hrs I took to do the mod.
Old Jul 6, 2008 | 10:54 AM
leekingen's Avatar
leekingen
that,s obout what i have experienced when i did mien.wow is all i can say
Old Jul 6, 2008 | 11:45 AM
F350-6's Avatar
F350-6
Thanks for sharing your results. The 1.2 MPG gain is impressive.
Old Jul 6, 2008 | 12:03 PM
Automator's Avatar
Automator
I need to look into this mod some more, sounds pretty easy. Looking through the threads it looks like the hardest parts are getting to the IDM and removing the lid (and then perhaps sealing it good). The "gel" on the board is a conformal coating to seal against water and the soldering will remove that protection. Years past I have fixed these by spraying hair spray in it's place where work was performed.
I found that ITW Chemtronics makes a conformal coating but haven't found who sells it, but can't imagine doing much with it afterward. Maybe I can convince my employer to buy some since we have so much trouble with water and electronics. I currently purchase various displays for the plant with the conformal coating due to our moisture levels.
Old Jul 6, 2008 | 06:07 PM
tag187's Avatar
tag187
I have also done the mod, though only had it finished it 2 days ago. I agree with all that was said. Highly recommend this mod to anyone with the ***** to break open their IDM
Old Jul 6, 2008 | 07:31 PM
jdecker88's Avatar
jdecker88
Well I do believe I might try this mod if it works well with Jody's tunes.
Old Jul 6, 2008 | 07:36 PM
nlemerise's Avatar
nlemerise
Here is a pdf on removing IDM lid
Old Jul 6, 2008 | 09:31 PM
mueckster's Avatar
mueckster
I dabbed a little clear RTV, with a Q tip, on the resistor and connections, when I did mine 5 weeks ago. Not one problem, so far. My overall observations of this mod were pretty much the same. Several cuts with razor knife and the lid came off pretty easy without bending. There are some pics in my gallery and what I used to seal the cover.
Old Jul 6, 2008 | 09:42 PM
schlepprock250's Avatar
schlepprock250
So...In short,will the IDM mod. work ok running a DP chip?80e,120,and so on.
Thx ....Schlepprock
Old Jul 6, 2008 | 10:26 PM
bigtorque's Avatar
bigtorque
from what ive read else where, the IDM mod works along with all other programs and mods.
dp-tuner+IDM mod+ICP mod= some real nice power.
Old Jul 7, 2008 | 12:27 AM
mueckster's Avatar
mueckster
I posted that I did this 5 weeks ago. But, it was actually about 9 weeks. Time flies when you're having fun. I have run the 140v IDM with all my DP Tunes with no adverse effects. I am actually making as good of mileage in the 120 tune and I did in the 80e.
Old Jul 7, 2008 | 11:54 AM
matty169's Avatar
matty169
Anyone want to send me a resistor for this mod. I cant find one in this area.I do have access to extra IDM.s if anyone needs one.
Old Jul 7, 2008 | 12:13 PM
kawajockie's Avatar
kawajockie
Can you see the IDM label before you tear into the truck? I want to ensure I have the correct resistor, before I start.
Old Jul 7, 2008 | 12:54 PM
Zephyr's Avatar
Zephyr
Matty169, If you will PM me your address I will send ya a resistor, I think I have a few extra.
Kawajockie, No you cannot see the label without pulling the inner wheel well out.
Old Jul 7, 2008 | 01:16 PM
kawajockie's Avatar
kawajockie
I have a 2003 Excursion, any way of telling by year, or is it just better to look?
Thanks
