My battery went dead about two weeks afo and I recharged it and the charge lasted about three to four days. When I open the door to my truck I could hear a draining noise come from the fuse box. What can I check or have anyone ever had this problem? Thanks
I did what you said. The battery reads 14.68 while running and a 13.33 while idle. When the door opens the battery reading starts lowering automatically. I look in the fuse box and the two large black box fuses felt really hot. Do I pull them out and if so how do I check to see if thats the problem?
No I did not. The only thing was installed was a new alternator about a year ago. When I open the doors to the truck the battery reading starts to go down. Something is draining the battery while its not running, I open the door to the truck the other day and I heard a draining noise from the fuse box and the battery was dead. I had my son open the dorr while I kept my meter on the battery and the battery began to drain while the door was open but when I closed the door it stopped. What gives?
try the other door and see if its the seam effect. either the dome light is pulling way to much, or the electric window motor or electric door lock wire is shorting out to ground when the door is opened. look for pinched wire harness by the door hinges????????
I removed one of the relays and the lights went out. I put the rel;ay back in and it started to make the noise I here right before the battery starts to drain. is that a sign of a bad relay?
