My check engine light is on and the O/D light is flashing. The code it keeps putting out is P0775. Even after replacing the solenoid pack it's still showing the same code.
I was told by a mechanic that my O/D bands needed to be replaced and something about the servo. Basically, he told me I would need an overhaul on the transmission to fix the problem. The 2nd and 5th gears are not being recognized.
I need to know if anyone else has experienced this and is there a simpler solution?
