Stereo power
Old Jul 5, 2008 | 10:13 AM
Shovelhead 93's Avatar
Shovelhead 93
Stereo power
I swaped an aftermarket deck in today,but there is no power going to the yellow wire,the red has power but not the yellow,I bought the adapter kit so I just colour match and plug in,but yellow is dead,I had to hook into the red to get power.
Old Jul 5, 2008 | 03:14 PM
Fosters's Avatar
Fosters
may wanna read what each wire does instead of color matching em...
Old Jul 5, 2008 | 05:44 PM
Matt983's Avatar
Matt983
I haven't swapped the radio in my truck yet, nor looked behind it but I think typically automotive speaking yellow is your 'accessory power" that only comes on when the key is in the ignition and turned on. Test it with a volt meter to be sure.
Old Jul 5, 2008 | 05:50 PM
black04lariat's Avatar
black04lariat
If you are talking about the harness that is a "female" onto the factory plug that allows you to go color for color to an aftermarket radio, yellow is constant and red is switched. I would check your fuses. Possibly when you were wiring it up you popped one.
Old Jul 5, 2008 | 05:56 PM
Shovelhead 93
ya i will have to check, I put a test light on it and no power,
Old Jul 6, 2008 | 11:23 AM
Shovelhead 93
I checked it was the fuse thanx alot.
reno138
Mar 12, 2014 02:26 PM
dpslusser
Sep 9, 2012 12:21 PM
my72ford
Bronco II
Mar 22, 2006 08:26 PM
Dutch123
1978 - 1996 Big Bronco
18
Mar 17, 2003 06:46 PM
