ford c7ae-a heads
Old Jul 5, 2008 | 08:03 AM
rodriguezfords's Avatar
rodriguezfords
ford c7ae-a heads
Are all C7ae-a heads GT heads i have a set from april 1967?
i have another question i have a c6ME-A block from date code 7d26 making it a 1967 block with the heads i mention earlier. but the crank is 2T making this block a 360 engine. but i thought 360s did not come out until 1968?
can someone calrify this
thanks
Old Jul 6, 2008 | 08:57 PM
trick1911's Avatar
trick1911
heads and block
the heads you talk about are 352/390/410/428ci made in 1967 and are High performance with standard valve and port size. (nice heads). the block ? 360ci cranks where produced from 1968-1976. the crank id's are 2T or 2TA. hope this helps.
Old Jul 7, 2008 | 01:18 PM
rodriguezfords
thanks for the information i just wanted to be sure the heads where high performance i plan on switchting the the crank and rods?
