door alignment
Old Jul 1, 2008 | 05:39 AM
FLN's Avatar
FLN
door alignment
just installed new rubber moulding around my doors. now my doors dont fit flush.ive moved the striker bolt as far as it will go,still a quarter inch off.they fit so nice before, but the moulding was worn out.is there a trick to adjusting these doors or do i just let time do its work?the moulding came from BOTP.
Old Jul 1, 2008 | 06:04 AM
Fritolay's Avatar
Fritolay
Are the bushings in your hinge Worn out?
have you tried loosening the hinge and moving the door out slightly? six bolts per door three per hinge
Old Jul 1, 2008 | 06:16 AM
Dave Severson's Avatar
Dave Severson
The new mouldings will compress a bit with time then you can readjust the doors to fit correctly. Mine did the same thing.
Old Jul 4, 2008 | 11:11 AM
DarkWolf40's Avatar
DarkWolf40
Dave's right, give it a month or two before you start moving doors around
Old Jul 4, 2008 | 12:05 PM
fordinlinesix's Avatar
fordinlinesix
Yup, I did that with mine, I thought my door was seriously misaligned because it was really hard to shut the door, after several weeks though it closes pretty east and seals tight.
Old Jul 7, 2008 | 05:46 PM
garbz2's Avatar
garbz2
Grant Peterson has a really good article on door adjustment in Bumpside Build off in the new issue of Classic Trucks
Garbz
Ponyboychris
Dec 27, 2018 04:56 PM
firemarshalmike
Paint & Bodywork
Feb 20, 2014 07:33 PM
Blue69gt
Ontario Chapter
Jul 15, 2011 09:38 AM
n5926g
2004 - 2008 F150
Nov 30, 2009 02:43 PM
Jim Heritage
1997 - 2003 F150
Jul 27, 2005 09:04 AM
