17* hpop? whats that all about?
Old 07-03-2008, 08:57 PM
89ford73's Avatar
89ford73
89ford73 is offline
i was just wondering why and how you set your hpop to 17 degrees verses the stock# of * what is the stock setting? why set it to 17? what if you set it to more? can you set it on a stock truck to make it run better?
Old 07-03-2008, 09:05 PM
scatgo's Avatar
scatgo
scatgo is offline
Cant be "set" as far as I know. Its the way it is made. Ill try to get you more info.
Old 07-03-2008, 09:16 PM
scatgo's Avatar
scatgo
scatgo is offline
Try this. Click on the links in this link........Diesel-Central.com the technical source for Diesel Truck information, Truck Pulling, and Drag Racing The angle is in the swash plate
Old 07-03-2008, 11:47 PM
89ford73's Avatar
89ford73
89ford73 is offline
ok, so the 17* has nothing to do with injection timing, just pump volume. they are saying that if you use a 99-03 psd hpop on our trucks it will run better than the factory 94-97 pumps. got ya! thanks for clarifying that.
new question, can you change the actual injection timing by jumping the camshaft 1 tooth foreward like in the big cummins truck motors??
Old 07-04-2008, 01:23 AM
kawa's Avatar
kawa
kawa is offline
Scatgo, that was a great artical, Great find!!!
Reps sent (If i Can)
Rog
Old 07-04-2008, 07:04 AM
scatgo's Avatar
scatgo
scatgo is offline
It is the ECM that sets timing based on information it gets from sensors. There are electronic ways to trick the ECM into changing timing like the 10K mod. Our trucks have a camshaft position sensor and jumping a tooth MIGHT change injector timing but I am sure it wont be worth all the work and you might wind up with a valve going through a piston. Things like the 10k mod takes about 2 minutes to do and undo and cost less than a dollar to do.
Old 07-04-2008, 09:11 AM
tjbeggs's Avatar
tjbeggs
tjbeggs is offline
x's 2!
the cam will only change valve timing which could result in valve to piston contact. If you want to change timing let a chip do it for you. Timing on a diesel is not nearly as forgiving as a gasser.
Old 07-04-2008, 10:24 AM
glasseater's Avatar
glasseater
glasseater is offline
this just reminded me of all the stuff i still need to do till i'm happy with this truck.... lol and the 17* pump flows much more oil then our 15* pumps
Old 07-04-2008, 02:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Thumbs up
Rog
X2, very good write up. Reps sent.
