Sponsored by: Auxito
9.75 rear end help !!
Old Jul 3, 2008 | 07:08 PM
councillor's Avatar
councillor
Diff case sitting on bench, I want to replace the postive traction discs under the side gears --- can anyone explain how to replace them?
Old Jul 4, 2008 | 10:55 AM
councillor's Avatar
councillor
Hasn't anyone replaced the Posi-trackion pack discs??
HELP!!!
http://i162.photobucket.com/albums/t...g/rearend3.jpg
Old Jul 4, 2008 | 05:04 PM
Bobby82490's Avatar
Bobby82490
From what ive heard... you need special tools to install the clutch discs... which sucks cause i want to replace mine too.
Do you have it apart just to replace the clutches, or are you changing gear ratio too?
Old Jul 4, 2008 | 06:33 PM
councillor's Avatar
councillor
Thx bobby for the info;
Yep, the ratio but have a extra 4:10 diff ....... i wanted to do this myself but special tools you mention must be the ticket.
3:73 is slipping and out as you see, my 4:10 in the L is fine but i like both ratio's, depends on the hook and tires.
Looked thru my Ford shop manual and naturally they have a special tool for everything but don't see exactly what i need, guess the D*** dealer is the only way.....huh!!
Old Jul 6, 2008 | 05:08 PM
Bobby82490's Avatar
Bobby82490
I looked around and some people say you can make the tool from common hardware store items... but i havent seen how to make it, just that some have.
Old Jul 6, 2008 | 07:12 PM
firefighter1416's Avatar
firefighter1416
i took mine to a gear shop to fix the chattering in the rear end, watched them take my clutch pack out with a big screw driver and pry bar they just walked the gears out. also another thing he did was made a tool that compressed the insides of the clutch to do that. sorry about the terminology don;t know what exacly everything is called in there. d
Old Jul 6, 2008 | 08:17 PM
AzBlueWolf's Avatar
AzBlueWolf
gear shop before dealer...especially when you have your own parts
Mark
Old Jul 6, 2008 | 09:21 PM
councillor's Avatar
councillor
Interesting, i might figure out to pry the pinion gears out but sure wish i had some idea about making this tool...
Old Jul 7, 2008 | 09:38 PM
councillor's Avatar
councillor
Inside the case (as per photo) theres 2 tabs on each axle spider gear and there must be some kind of tool -------- in order to get them out !!
http://i162.photobucket.com/albums/t...g/rearend6.jpg
http://i162.photobucket.com/albums/t...g/rearend7.jpg
Old Jul 8, 2008 | 08:05 AM
Bobby82490's Avatar
Bobby82490
Those tabs are the clutches.
Old Jul 8, 2008 | 01:41 PM
councillor's Avatar
councillor
Yep, see them but still don't understand how the thing comes apart.
Bob Karenbauer
Jan 8, 2014 06:28 PM
Jermafenser
Aug 19, 2002 01:39 PM
aerocolorado
Aerostar
Dec 20, 2001 02:49 AM
jowilker
Jun 13, 2001 04:42 PM
Boss_358
Jan 10, 2001 05:11 PM
