Need some info
Old Jul 3, 2008 | 03:27 PM
mndiesel's Avatar
mndiesel
Need some info
I am looking at a 2006 f350 lariat dually with about 72xxx miles. I have a 99 7.3 and am just wondering how the 06 6.0 are. I am going tonight to look at it and just wanted to here good and bad stuff about them before I go. I am not trading in the 99 just the wife 04 4runner. Asking price $23999.
Old Jul 3, 2008 | 03:41 PM
BGMSPD's Avatar
BGMSPD
run an oasis...the thread is at the top of the screen. it will give you what you need to know.
Old Jul 3, 2008 | 03:56 PM
mndiesel's Avatar
mndiesel
Thanks for the info
Old Jul 3, 2008 | 04:40 PM
Sarge261's Avatar
Sarge261
I Love everything about my 06. I had an 04 early build that I had lots of problems with but this one is night and day. You will love it too. See if you can work in an extended service plan on it just incase. You still have the remainder of the engine warranty but its piece of mind and with diesel prices now they may throw it in just to get rid of it.
Sarge
Old Jul 4, 2008 | 06:11 AM
bismic's Avatar
bismic
Personally, I think 23,999 is too high. As Sarge said, at least get an extended warrantee thrown in w/ it.
BUYING A USED 6.0L
If you are looking at used 6.0's here are a few considerations (along w/ the OASIS and CARFAX reports that are essential).
Some 6.0L weak points (things to check):
Look for signs of coolant degas bottle overflow (dry white residue on and around the degas bottle or no level in degas bottle).
Lots of idling can cause EGR problems. I look at the hours on the engine (if it has this monitored) and divide the miles by the hours (is it below 30? If so, may have had lots of idling).
Even without much extended idling EGR valves can plug quickly - maybe negotiate for a new EGR valve. In fact, I would negotiate for them to pull the EGR valve to inspect it (have them show it to you when it is out and then you need to look into the intake). Check for wetness (w/ rear end jacked up) and for excess soot. Wetness indicates an EGR cooler leak. If the valve is gunked up, have them replace the valve. If the intake is real bad, you may push them to clean it as well.
Look underneath for oil leaks - some trucks have had a lot of them
If you buy from a dealership, I would negotiate for them to install the latest flash of all 3 processors.
Negotiating for an extended warranty is always a good thing as well.
Try to find out about the routine maintenance:
• Filter change intervals on time? What kind of oil (CI4+ or CJ4 - one of these is required)?
• OEM filters? Look at them and see what kind they are. Aftermarket filters can cause MAJOR problems.
• Find proof of Transmission being flushed/changed - it is recommended every 30,000 miles.
• Any exhaust problems visible (i.e. lots of white or blue smoke)? White smoke may mean an EGR cooler leak.
Check for any FLUID leaks (as stated previously - LOOK SPECIFICALLY FOR OIL LEAKS - 6.0L are prone to many of these from many possible places!!)
CEL (Check Engine Light) on? Consider getting a code reader and check for DTC's. You can have active DTC’s without a CEL.
The Electronic Shift on the Fly ESOF sometimes fails due to vacuum leaks. Be sure to check this out (several times in and out of 4WD).
Check for excessive wheel bearing wear (looseness), stabilizer bar looseness, or ball joint looseness. Ball joints tend to go out in the 70k-90k range.
Check the coolant - it should have the Motorcraft Gold Coolant - anything else and there may be problems. Look in the "degas" bottle and inspect the fluid - it should be gold colored and there should be NO OIL visible. As previously stated, the degas bottle should not have white residue around the sides of it (possible overheating issues)
Any evidence of a tuner (aftermarket air filter, gauges, etc)? Tuners may or may not be bad. Some tuners are MURDER on the transmission. Some dealerships will cause you a lot of problems w/ them - even if you bought it that way used.
Aftermarket air systems could be a problem. Many of them (like K&N) do not filter as well and could cause issues. Up to 500 hp, the stock air system is best!
Try to find out if the original owner ever ran it empty on fuel or have plugged filters?
Then the common stuff I'm sure you know:
• Look at and smell the fluids. Make sure fluids not burnt, not too thick or dirty.
• Check the tires - should have over half the life left at this mileage - abnormal wear?
• How do the brakes look? Any pads need replacement? Are the rear brakes excessively worn?
• All electronics working? Especially the AC?
• Dents? Air bag been replaced, etc.
• See if he has any repair or maintenance records.
• Take off the price for windshield dings, paint chipped, torn upholstery, etc.
• Does the truck look too clean? Does it look like the oil was just changed? May be hiding something
• Any extras - tool boxes, bumpers, etc.?
• Drive it - does it hesitate or surge? Does it blow white or black smoke? When driving, brake fairly hard - note any pulls, pops, clunks, rattles, etc. How does it accelerate? You should romp on it pretty good. Drive in reverse and then back and forth - listen for clunks.
Old Jul 4, 2008 | 11:52 AM
southbound35west's Avatar
southbound35west
well that list should cover it all....................................i love my 2006, it has 63k on it now and still runnin strong, this is the strongest pulling truck i have ever had, and the toughest truck i have owned to date, i pull some reaally heavy loads with mine (12,000-14,000lbs), it handles the weight well powerwise, but i wish i had dual tires sometimes for more stability when towing heavy.............try and get them down to $22 and get it!!!!!!!!!
Old Jul 5, 2008 | 07:38 PM
Sarge261's Avatar
Sarge261
I agree with you guys, 23,999 is way too high. I paid 21900 for mine in February and I got a 4/48k Premium Care 0 deductable with mine. It nly had 50,000 on it when I bought it. Get em down some and make sure everything checks out with the list bismic gave you and push for the ESP.
Good Luck,
Sarge
helifixer
29
Apr 14, 2013 09:48 AM
SuperDutyF250
Oct 25, 2005 10:49 AM
Triton PI
1997 - 2003 F150
Jan 14, 2005 08:17 PM
jeepbilt
Sep 26, 2003 07:39 AM
