Speedometer
Old Jul 2, 2008 | 12:08 PM
AndysFords's Avatar
AndysFords
Speedometer
On the 93-94 Trucks with the electronic odometer, is there a way to recalibrate them without putting a new gear in them?
Old Jul 2, 2008 | 04:37 PM
David85's Avatar
David85
If you are thinking of an axle ratio change, than there is no need to recalibrate the speedometer because its signal is taken off the axle speed regardless of what differential gears you have.
If you are compensating for a taller tire diameter, than that gets more complicated. I think there may be aftermarket chips that can intercept the VSS signal and step it up or down to calibrate the speedometer signal, but thats beyond my knowledge.
Old Jul 2, 2008 | 10:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
If I could find the right link there is a supplier that sells a box to convert the speedo reading.
But you only need it when running taller tires.
There is no gear in the axle mounted setup.
Old Jul 5, 2008 | 11:31 PM
AndysFords's Avatar
AndysFords
The truck I just bought has 295 tires on it and the speedo is off 20%
Old Jul 5, 2008 | 11:46 PM
Dave Sponaugle
Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
You may want to call and see if this will work for you.
Old Jul 6, 2008 | 08:22 PM
LilDuke's Avatar
LilDuke
92+ year trucks with the digital odo can be changed right at the dash board. Somewhere buried deep in my bookmarks is a thread, I think from this forum that tells you how to do it.
Old Jul 6, 2008 | 09:05 PM
Dave Sponaugle
HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
Found that link also.
Old Jul 6, 2008 | 10:41 PM
David85's Avatar
David85
Originally Posted by Dave Sponaugle
Hey thats pretty cool. Didn't know that th eigital speedos could be changed that easily.
