help replacing thermostat
Old Dec 9, 2002 | 10:50 PM
spur's Avatar
spur
I need to change the thermostat and gasket on my 89 F-250 (351W) and have never replaced one nor do I know where it is. Can anyone help guide me through this or do you know of a diagram I can inspect? Thanks for any help.
Old Dec 9, 2002 | 10:59 PM
Mil1ion's Avatar
Mil1ion
Follow the upper rad hose to the housing.
You need a :
Thermostat
Thermostat gasket
Gasket glue unless the gasket has a pre-glued face.
You need to drain the rad at least below level with the water pump.
If the coolant has deteriorated,replace it.
Do a flush & fill.
Once the new thermostat is installed > tighten housing to spec,make sure the drain for rad is plugged and refill to a 50-50 or 60-40 solution.
Dennis
F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/SigSanta.JPG
[font color=red]
"May The Spirit Of Christmas Be An Inspiration To You Throughout The Year"
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Dec 15, 2002 | 03:00 PM
mathelm's Avatar
mathelm
