Aerostar Ford Aerostar
rear hatch latch
Old Jul 1, 2008 | 08:00 PM
z1121jack's Avatar
z1121jack
rear hatch latch
I purchased 97 aerostar last Friday. Every thing seemed to be working (a/a/c radio, elect, windows and door locks. Then on Sunday my "door ajar" light came on. I found the rear door unlatched and it still is I removed the inside panel covering the latch mechanism but looks like everything is OK? The things I tried with no luck include:
manually tripped and reset latch
switched the elect door locks on and off several times
tried to open and close the lock with a key
loosing my temper
has any one else had this problem? advice appreciated
Old Jul 2, 2008 | 12:17 AM
marty600's Avatar
marty600
The sensor is inside of the latching assembly-and is it retracted, or extended. My 93
did this..rust was the cause...get paper towels ready, and spray all over with your fav. wd40 clone. actuate with handle. It will go away, I bet. (Ranger door handles are notorious for this. Use the red tube, make a mess, won't hurt wiring.
Old Jul 2, 2008 | 06:39 AM
z1121jack's Avatar
z1121jack
thanks marty I'll try it.
pwstroker69
Mar 17, 2015 08:37 AM
mike L
Dec 19, 2012 10:56 AM
ErrorS
1978 - 1996 Big Bronco
Oct 24, 2009 12:23 AM
Franzh
Oct 23, 2008 08:37 PM
4running
Jan 31, 2007 11:56 AM
