2003 SD heater bypass ???
Old Jan 1, 2003 | 08:48 AM
bosshoss's Avatar
bosshoss
Old Jan 1, 2003 | 12:53 PM
Woodtroll's Avatar
Woodtroll
Hello folks. I'm trying to figure out how the coolant valve to the heater core works on the 2003 models. I had planned on doing the coolant valve/ AC mod, but found it had already been done (to some extent) when my truck arrived. But, what actuates the coolant valve, and which way (vacuum or no vacuum) makes it close? My goal is to have the vent air the same temperature as the outside incoming air (I know it'll be slightly warmer due to engine & turbo heat). I use the vents a LOT, but don't like the AC except in very hot weather. I had thought about tying in a microswitch to the extreme cold setting on the temp. selector, to work an electric/ vacuum valve that would close the solenoid. I've seen this mod posted before. It's been too cold here to tell if the vent air is outside temperature or not. Any ideas/ suggestions? Thanks, Regan
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
