Another fuel tank issue
Old Jun 30, 2008 | 07:16 PM
tomandbeth's Avatar
tomandbeth
Original owner, and I always run the tanks dry before switching over. Anyway, filled my tanks and switched to the front tank (had run dry) to force any air out, and no fuel. Switching to the rear tank all is well.
I'm guessing my in tank pump finally died. Looking in the archives I can check for fuel pressure using a basic air pressure/vacuum guage?? did I read that correct? I also looked in the archives for any "do this first, then this, then this" type procedure until diagnosed, but didn't see one.
Finally, assuming that I do fault diagnose to the in tank pump, would you recommend I siphon the gas out first?
Gee, guess what I'm doing over the holiday :-(
Old Jun 30, 2008 | 08:00 PM
60F100's Avatar
60F100
I presume this is an EFI engine in which case the basic air pressure/vacuum guage won't handle it. You need a fuel pressure guage that hooks to the fuel rail. I don't remember the pressure offhand but should be around 30 psi. If you constantly run the tanks dry I would think you could be sending trash to the fuel filter. You should be able to hear the pump run when you turn the key on. Is only one tank acting up or both?
Old Jun 30, 2008 | 08:14 PM
tomandbeth's Avatar
tomandbeth
Only the front pump. I stay on top of maintenance items like the fuel filter and have never had a fuel problem until now.
Thanks for the info on the pressure test,
Old Jun 30, 2008 | 08:26 PM
bluesman2333's Avatar
bluesman2333
Running pumps dry is a good way to kill them. I'm surprised it hasn't happened sooner.
Old Jun 30, 2008 | 08:46 PM
galaxie641's Avatar
galaxie641
Yep, anything under about 1/4 tank and they will overheat and you kill them in a hurry. Since there are screens on the pick up and it is at the bottom of the tank I don't think running the tank "dry" will cause any problems with crap in the filter. As said above the easiest way to check the pump is to listen for it when you turn the key on.
Old Jul 1, 2008 | 09:21 PM
tomandbeth's Avatar
tomandbeth
What can I tell you guys? From the looks of things "killing them in a hurry" equates to 12 years and 166K miles.
But hey, thanks for answering the questions.
