LIght Switch
Old Jun 27, 2008 | 09:26 AM
Dre82s's Avatar
Dre82s
LIght Switch
SO i have this very weird thing going on in my truck. if I turn on my light switch all the way out for headlight use my my rear light wont come on, my front orange light wont come on and my dash light wont come on. I have already replaced the switch, could it be a bad switch or what? 1988 f 250 4x4 302
Old Jun 27, 2008 | 11:57 AM
phoneman91's Avatar
phoneman91
What happens when you just turn on the parking lights?? If they dont come on neither--check for blown fuses.
Old Jun 27, 2008 | 12:51 PM
quicklook2's Avatar
quicklook2
bad grounds?
Old Jun 27, 2008 | 03:10 PM
F150xlt's Avatar
F150xlt
Fuse #4 provides 12 volts for the parking/running lights and the dash back lighting.
If your horn and cigar lighter work the 12 volt feed going to the fuse panel for the #4 fuse is at least getting to the fuse panel.
If they don't work most likely the Black/Orange wire fusible link at the starter solenoid is blown. In that case the headlights also would not work.
If both work use a volt meter and see if the 12 volts from the battery is getting to the #4 fuse. It's hot all the time.
Here's a schematic of the fuse panel. #4 fuse is towards the bottom right of the schematic.
This is the schematic for the parking/running lights.
This is the schematic for the cluster lighting.
Old Jul 1, 2008 | 10:03 PM
Dre82s's Avatar
Dre82s
Hey guys thanks for all the help and it was the fuse, no need to have replace the switch other than it gives me the diming in the cab.
