Charging Issues
Old Jun 29, 2008 | 02:47 PM
GELGIN58's Avatar
GELGIN58
Charging Issues
I have a 81 F-150 that stopped charging. Alternator,regulator and battery check out.Any suggestions?
Old Jun 29, 2008 | 08:39 PM
power_speed's Avatar
power_speed
I am thinking it is most likely a fusible link. Or perhaps just a broken wire. You might consider a new wire harness for the alternator to the battery.
To check just take a ohm meter and measure for continuity on both sides of the wire.
Old Jun 29, 2008 | 09:55 PM
Franklin2's Avatar
Franklin2
You can also check for a bad fusible link in the alt system by check for battery voltage on the back of the alternator output terminal, with the engine off.
Old Jun 30, 2008 | 03:35 AM
srercrcr's Avatar
srercrcr
Well, just about the only thing left is the simplest and cheapest....remove the major cables and wirebrush the ends along with where they attach.
