shift lever problems
Old Jun 29, 2008 | 10:27 AM
Antony c.'s Avatar
Antony c.
I have a 93 ford f-150 and I cant get it out of park. Any suggestions.
Old Jun 29, 2008 | 11:27 AM
mhg's Avatar
mhg
start by checking your brake light fuse
if the fuse is good you can disconnect the lock solenoid by unplugging it
the access to it is at the lower end of the column on the left side
Old Jul 1, 2008 | 03:32 PM
lostin90s's Avatar
lostin90s
Also check linkages in colum as they come loose and bind. Or a failing shift tube .
