Compatible kickdown rods
Old Jun 29, 2008 | 12:23 AM
sum_weirdo's Avatar
sum_weirdo
Was at PicknPull today and decided this was a good time to find a replacement for my truck's missing kickdown rod. Unfortunately the pickings were unusually slim today, the only 70's F-Series I could find was a 76, the badges were missing but I'm thinking F100 or F150. Had a small block engine whereas mine has a 460. Now I'm not sure but I sorta think Ford probably made a few different kickdown rods for different applications. Or am I wrong? If I can take that rod and adjust it to my needs then great I'll go get it. Anyone know?
Old Jun 29, 2008 | 12:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Kickdown rod / 1973/79 F100/350 / 460/C6
According to the parts catalog, 1973/74 & early 1975 (before serial # V80,001) is the same (D4TZ-7A187-A).
Late 1975 (after serial # V80,001), 1976/77 is different (D5TZ-7A187-A).
1978 is different than the two previous rods (D8TZ-7A187-C - 20.83" long).
1979 is different again (D9TZ-7A187-A).
None of these parts numbers were used on any other engine/trans combo, 1973/79 F100/350 460 only.
None of these part numbers have been updated and all are obsolete.
Dunno why Ford has soooo many kickdown rods for just one engine/trans combo, but this is typical.
Internet search: No Ford dealer has D8TZ-7A187-C, no Ford parts obsolete seller with a website has one either.
btw: Junkyards = 1978 Customs have round headlamps, Rangers have rectangular headlamps.
1977/79: The year of the truck is stamped on the second line of the Warranty Plate, which is located on the left door face below the latch.
Engine ID: 460's have 7 valve cover bolts / 351M/400's have 8 / 302's have 6 / 360/390's have 5.
Old Jun 29, 2008 | 01:04 AM
76f350spercamprspeal's Avatar
Whats a kickdown rod?
Old Jun 29, 2008 | 09:22 AM
sum_weirdo's Avatar
sum_weirdo
Lol. The kickdown rod runs from the throttle linkage to the transmission. It's only function is to downshift automatically when the truck is under load. You can get by without one but in the case of mine it makes the truck a real dog when climbing hills.
Thanks for the numbers NumberDummy. Looks like I'm out of luck for now unless I get the Lokar kickdown linkage (way expensive).
Old Jun 29, 2008 | 03:23 PM
You should always get the best parts.
Your Friend
76SCS.
Old Jun 29, 2008 | 06:50 PM
78Ranger_GARedNeck's Avatar
78Ranger_GARedNeck
yep.. my passin gear rod wont work on my truck anymore.. i put a 3inor so carb spacer on it and the rod wont wrk... ive been tryin to find out how to extend it.. there isnt any adjustment. any ideas.. sum1 else said just to bend it.. it isnt long enough for that.
Old Jun 29, 2008 | 07:07 PM
Dr. Dirt's Avatar
Dr. Dirt
so if you have a manual transmission then you don't have a kickdown rod?
Old Jun 29, 2008 | 07:23 PM
73f100shortbed's Avatar
73f100shortbed
Yes Dr. Dirt manual trans. does not have a kickdown. 78Ranger maybe you can weld some threaded rod into make it longer and adjustable?
Old Jun 29, 2008 | 07:29 PM
Dr. Dirt's Avatar
Dr. Dirt
thanks a lot 73f100shortbed.
Old Jun 29, 2008 | 07:31 PM
73f100shortbed
No problem Dr. Dirt
Old Jun 29, 2008 | 09:29 PM
Thats great idea,73f100shortbed,your a great man.
Old Jun 29, 2008 | 10:05 PM
psquare7575's Avatar
psquare7575
I took my small block one, tweaked it a bit and lengthened it, and it works on my 460 just fine. Cost = $zero.
Old Jun 29, 2008 | 10:37 PM
boggin79ford's Avatar
boggin79ford
i went to the junkyard and got one off an 80s truck with a 460 and it was the exact same as the on i origannly had before i crushed it when i put in my new motor
Old Jun 30, 2008 | 03:52 PM
sum_weirdo's Avatar
sum_weirdo
Okay I was there again today and verified that the 76 I found before was an F150 with a 360/390. I would've grabbed its kickdown then but I wasn't really dressed to wrestle with it. Think it's worth going back for?
Old Jun 30, 2008 | 04:01 PM
Thunderjet4x4's Avatar
Thunderjet4x4
Yep, bend and or add length to make it work. I'm not positive but the kickdown helps the transmission build more pressure?
My C6 lost second gear eventually when I ran no kickdown, but it coulda been a bunk trans also.
