Was at PicknPull today and decided this was a good time to find a replacement for my truck's missing kickdown rod. Unfortunately the pickings were unusually slim today, the only 70's F-Series I could find was a 76, the badges were missing but I'm thinking F100 or F150. Had a small block engine whereas mine has a 460. Now I'm not sure but I sorta think Ford probably made a few different kickdown rods for different applications. Or am I wrong? If I can take that rod and adjust it to my needs then great I'll go get it. Anyone know?
Lol. The kickdown rod runs from the throttle linkage to the transmission. It's only function is to downshift automatically when the truck is under load. You can get by without one but in the case of mine it makes the truck a real dog when climbing hills.
Thanks for the numbers NumberDummy. Looks like I'm out of luck for now unless I get the Lokar kickdown linkage (way expensive).
yep.. my passin gear rod wont work on my truck anymore.. i put a 3inor so carb spacer on it and the rod wont wrk... ive been tryin to find out how to extend it.. there isnt any adjustment. any ideas.. sum1 else said just to bend it.. it isnt long enough for that.
i went to the junkyard and got one off an 80s truck with a 460 and it was the exact same as the on i origannly had before i crushed it when i put in my new motor
Okay I was there again today and verified that the 76 I found before was an F150 with a 360/390. I would've grabbed its kickdown then but I wasn't really dressed to wrestle with it. Think it's worth going back for?
Yep, bend and or add length to make it work. I'm not positive but the kickdown helps the transmission build more pressure?
My C6 lost second gear eventually when I ran no kickdown, but it coulda been a bunk trans also.
