fuel guage/selector problem
Old Jun 29, 2008 | 12:16 AM
greenwoodford's Avatar
greenwoodford
My truck has been converted from a long bed with dual tanks, to a short bed with only rear tank. The wiring for the rear part of the truck was also botched up pretty good. The selector valve was left in place and the line capped off for the front tank. Recently the selector valve went bad (I think) so I just bypassed it. When the switch is in the up position the guage reads full, but when it is down it goes skitzo. Sometimes it works right, but other times it just doesn't work at all and stays on empty. Is the up position for the front tank and the down position for the rear tank? How would I go about troubleshooting this? I searched and found some posts, but they were all too old and the pictures didn't work anymore. Thanks.
Bill
Old Jun 29, 2008 | 07:43 AM
F150xlt's Avatar
F150xlt
If this is for an 88 F150 here are the schematics.
Pressing the top of the rocker switch in is for the Front tank. The switch usually has a F painted on it.
Pressing the bottom of the rocker switch in is for the Rear tank. The switch usually has a R painted on it.
Since your gauge does work sometimes, most likely you have a bad sender.
This schematic is for the Gas engines.
This schematic is for a Diesel engine.
Old Jun 29, 2008 | 12:04 PM
greenwoodford
Sorry I forgot to say that my truck is an 88 F250. It should be similar schematics though right?
Old Jun 29, 2008 | 01:32 PM
F150xlt's Avatar
F150xlt
Schematic is the same for f150-F350 gas engines.
Old Jul 26, 2008 | 11:24 PM
dyoungen's Avatar
dyoungen
Question fuel tank selector valve
I have a 1987 F250 Diesel that I believe the fuel tank selector valve quit working. I was told the FTSV is the same for all F250's. I found one from an '84 F250 but the plug is different and the Ford dealer doesn't have an up to date wiring diagram. Any ideas?
Old Jul 27, 2008 | 12:19 AM
greenwoodford
My situation is a bit different I think because my truck has been cut up quite a bit. I only have one fuel tank now so I just completely bypassed the FTSV. I used one of the in-line filters as a connector with the plastic lines to rubber line and did it that way. I think my issue is in the in tank sending unit maybe. I will have to drop the tank to find out.
Old Jul 31, 2008 | 03:32 PM
dyoungen's Avatar
dyoungen
Ftsv????
Would you be interested in selling the fuel tank selector valve that your not using?
Old Jul 31, 2008 | 04:12 PM
greenwoodford
Well, my fuel is bypassing the valve but my guage still reflects on which tank is selected. I'll have to get one of my friends over to see if we can rewire the fuel guage. If we can I don't have any problem selling it to you. Hopefully I'll have time to look at it this weekend. I'll let you know either way though.
