I’m having some issues with my brakes that I just can’t figure out. The problem is that my brake pedal is low. I can stop fairly well, but I must travel great distances with my foot. This is a major problem because I’m lazy. When I bleed the system, the firmness of the break pedal is immediately restored but to no avail, around three to five days later my pedal is low again.
I’m not losing any fluid, so I was guessing it was the master cylinder. I’ve already replaced it three times in the past month from different parts dealers and none of them fixed the issue. My hypothesis is that I’m getting air in the system somewhere, but for air to get in fluid has got to go out somewhere, right?
Let’s just assume that it isn’t the master cylinder. What can I check?
Pretty unlikely to get 3 bad MC in a row, presuming they were new. How did the bench bleeding go?
No. Air that gets in does not equate to fluid going out. Air in the lines & components acts like a spring, increasing pedal travel. The fluid that's displaced doesn't "go out" it returns to the reservoir.
There's been considerable discussion on rear drum brake adjusters. Seems that many people have had a lot of trouble w/them. If your rear brakes are out of adjustment you'll have a lot of "travel" before shoes contact drums.
... If your rear brakes are out of adjustment you'll have a lot of "travel" before shoes contact drums.
I was thinking about mentioning this, but if it is firm right after he bleeds it then shortly after it starts getting a mushy pedal.. i would think out of adjustment shoes would be unlikely.
Now if you couldnt get a firm pedal, then out of adjustment shoes could be a likely culprit.
How many times have you bled the brakes and then they get mushy?
Bench bleeding went fine. I had plastic lines coming out of both ports and placed the other end of the line back into the reservoir submerged in fluid. Then after about 10-15 slow pumps, no bubbles.
I've checked through peep hole on the backing plate on the rear drums and the shoes are all the way against the drums. Also, I pulled the drums off and adjusted the shoes out as far as possible to the point where the drum wouldn’t even go back on... so I then backed the shoes off a little.
A faulty ABS sensor on the rear differential has been known to cause a mushy brake pedal. If bleeding doesn't solve your problem you may want to check that.
