fuel line?
Old Jun 28, 2008 | 03:21 PM
kent's f-350's Avatar
kent's f-350
fuel line?
hello all, on the right side of the fuel filter housing there are 2 s.s. braded lines going into the heads. is that a high pressure fuel line?
Old Jun 28, 2008 | 05:01 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I think you are talking about the lines comming off the HPOP.
Old Jun 28, 2008 | 06:20 PM
MTDewX's Avatar
MTDewX
I am sure the fuel lines are Solid. I agree with Miller_feed that they are from the HPOP.
Old Jun 28, 2008 | 06:34 PM
miller_feed
We don't have high psi fuel lines. We have high psi oil lines. These lines feed the injectors in order for them to fire.
Old Jun 28, 2008 | 10:20 PM
kent's f-350
ok, the one braded one going to the right side is leaking oil, and if it is a hpop line that would make sense.
thanks
Old Jun 29, 2008 | 07:32 AM
Pocket's Avatar
Pocket
If it's leaking oil from those lines, you may want to get it fixed soon. When the o-rings on those hoses let go, you'll dump gallons of oil in a matter of minutes, and it will leave you stranded on the side of the road.
Old Jun 29, 2008 | 08:25 AM
AustinS's Avatar
AustinS
As Pocket said, don't put off this leak. It's not just a nagging little leak. You can get the o-rings and the special loc-tite for the fittings here:Replacement O-rings for Diesel Engines
Good luck,
Austin
Old Jun 29, 2008 | 08:37 AM
HKusp's Avatar
HKusp
Good link Austin, reps sent. I can't rep Curtis or Rick until I spread it around...
Old Jun 29, 2008 | 11:45 AM
kent's f-350
what o-ring kit is it? thanks
is it oil or fuel in them lines, as thier is steel lines on the left side that go?
