Sponsored by: Auxito
Wheel help!!
Old Jun 28, 2008 | 01:50 PM
bgphotoo's Avatar
bgphotoo
Wheel help!!
I am looking for used rims on a local site. My problem is I'm not sure what I'm looking for. For example what does 5X100 mean? I know the five is for the lug nuts but what is the 100 and how do I masure that? At the moment I have standard 16" rims but I think I would like to put bigger tires on it. Should I go up to a 17" rim? Will rims for a chevy fit a ford? Does the year matter? I have a 2001 F150 XL 2X4. Thanks for any help!
Old Jun 28, 2008 | 01:58 PM
sheetsd66's Avatar
sheetsd66
There's another thread already started on this topic:
https://www.ford-trucks.com/forums/753777-help.html
Old Jun 28, 2008 | 02:09 PM
bgphotoo's Avatar
bgphotoo
Thanks so much, sheetsd66
Old Jun 28, 2008 | 07:34 PM
galaxie641's Avatar
galaxie641
You have 5x135 with 14mm studs, plan accordingly. I haven't known any chevy rims that fit Fords for a very very long time. They haven't had the same bolt pattern for quite a while. Usually Ford and Dodge are the same. Also remember yours are metric AND hubcentric.
Old Jun 28, 2008 | 07:48 PM
bgphotoo's Avatar
bgphotoo
Thanks galaxie, That is much help!
Old Jun 29, 2008 | 11:47 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The 5x135mm bolt pattern is unique to Ford. DO NOT use wheels from another brand of vehicle. They WILL NOT fit correctly.
The wheels on these trucks are also hub-centric. Not the typical lug-centric. In Hub-centric, the weight of the vehicle rides on the inner hole of the wheel. The lug-nuts are purely there to hold the wheel on...NOT to support weight.
Lug centric are the opposite, as the lugs hold the wheel on AND support the weight of the vehicle.
Old Jun 30, 2008 | 12:04 AM
khadma's Avatar
khadma
Carpenter Local 745
Lug centric wheels will have a conical seat for the lug nuts and of course will need conical lugs.
These 5x135 wheels are flat at the lug connection point of the wheel.
With that, the lugs are flared and have a flat mating surface.
Like ATC said, this wheel set up is unique to Ford trucks.
