Sponsored by: Auxito
Help!!!
Old Jun 27, 2008 | 07:58 PM
Rayleen's Avatar
Rayleen
Help!!!
I have a 2001 ford f-150 extended cab, and i just bought 20" rims for it, but when i went to get them put on they did not match my lug pattern, how do i know whick rims to buy for my truck that will fit
Old Jun 27, 2008 | 08:10 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello Rayleen and welcome to FTE! You truck has a 5 x 135 bolt pattern. 5 lug bolts on a 135 mm bolt circle. Good luck!
steve(ill)'s Avatar
steve(ill)
a 2001 should have 5 bolts to the pattern, they are on a 135 mm circle. older 1/2 ton trucks were on a 5.5 inch pattern, that might be the trouble if you said 1/2 ton ford.
Old Jun 27, 2008 | 08:38 PM
Rayleen's Avatar
Rayleen
so when i am looking for rims i need the same pattern 5x135mm?
Old Jun 27, 2008 | 08:42 PM
mitch150's Avatar
mitch150
That's what your looking for
ck22
Dec 14, 2013 06:12 AM
jonsk
Sep 25, 2011 11:33 AM
lakewood
Sep 17, 2011 10:02 AM
excoelis
2009 - 2014 F150
May 20, 2010 09:24 PM
Weevil
Nov 13, 2005 06:36 PM
