need transmission help
Old Jun 28, 2008 | 11:19 AM
cbslayer's Avatar
cbslayer
ok i have a 1994 f150 ext cab 4x4 5.0l with auto overdrive with ac i need to buy a trans filter kit but not sure what trans i have i found a tag on trans with bar code on it and these numbers F4TP-FA,PRABB2,00011033 AND BD-3K19 i also found a casting number i could barely read some of it but i think its FOTP-700G-0B any help would be apreciated i am also puting a external trans cooler and wondering the best method should i run it in series with the radiator or just run it seperatly which way would help it stay cooler and not trash my trans
Old Jun 28, 2008 | 11:58 AM
Lazy K's Avatar
Lazy K
Look up at the top of the page that your post is on, you will see a post titled "tech info". Click on that and then on the link to identify your trans. by VIN code or the link to identify by bolt pattern.
Old Jun 28, 2008 | 12:25 PM
cbslayer's Avatar
cbslayer
i will do that thank you checking now
Old Jun 28, 2008 | 12:32 PM
cbslayer's Avatar
cbslayer
cool e40d thanks much lazy k
Old Jun 28, 2008 | 01:10 PM
quicklook2's Avatar
quicklook2
run it in series with the radiator coolant tank.
drain the convertor or you are wasting your time.
remove rubber plug and tap ign. key until drain bolt lines up.
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1989/95 E4OD Transmission Filter
For this application: 1994 F150 4WD
F6TZ7A098BB > > replaced by > > YC3Z7A098BA .. A/T Filter (Motorcraft FT114)
MSRP: $32.18 / ftepartsguy.com price: $17.38
Old Jun 28, 2008 | 01:21 PM
cbslayer's Avatar
cbslayer
man above and beyond duty you guys come thru i love this site i didnt know the converter had a drain plug i was wondering how i was gonna empty it and now i can walk in the part store with the part number
Old Jun 28, 2008 | 03:28 PM
quicklook2's Avatar
quicklook2
the ford part store at least.
Old Jun 28, 2008 | 03:43 PM
NumberDummy
Some autoparts stores carry Motorcraft. If they don't, it takes only a few seconds to cross the Motorcraft part number over to the brands they sell.
Old Jun 28, 2008 | 04:09 PM
quicklook2's Avatar
quicklook2
i do recommend getting a motorcraft trans filter and i seem to only find them at ford or online.
fabsroman
Mar 6, 2016 09:08 PM
427ford
Jan 16, 2016 08:34 AM
vpoolman
Apr 22, 2015 09:03 PM
Recycle Performance
Nov 8, 2014 11:03 AM
Supercab
Jul 22, 2011 08:47 AM
